Now where did I put that???
Re: Now where did I put that???
I finaly got round to fitting the electrics for my phone/satnav.
Just need a holder for it.
And fitted the pannier racks.. Not sure if I want them on or not...
Also took it for a quick test.
I think my carb is kapput. It keeps dripping out of the over flow (float needle buggered) and I am struggling to get a desent tickover.
It has been stripped and cleaned. Had new airbox and manifold rubbers. I have had the mixture screw from 1 1/2 to 3 turns out.
The engine has had new stem seals, valves lapped, tappets set twice, the timing checked and rechecked.
Will try Gronks spare carb and see if that sorts it...
looking really nice rus. shame about the carb..teething troubles mate
dont turn your back on it ,gronk will swap the plates over.
Try the old soak the needle in WD40 overnight or MEK.rustybike wrote:I think my carb is kapput. It keeps dripping out of the over flow (float needle buggered) and I am struggling to get a desent tickover.
Ta,
Done that.appyarry wrote:Try the old soak the needle in WD40 overnight or MEK.rustybike wrote:I think my carb is kapput. It keeps dripping out of the over flow (float needle buggered) and I am struggling to get a desent tickover.
Ta,
The carb is going into the sonic cleaner tomorrow. If that don't cure it, it's going in the bin
There is always a market for spare parts or it may help you out for parts later. At the worst scenario clean the jet with alchohol or MEK etc and then put a new float needle in, assuming you can still get a float needle. One thing to be aware of is not to get any lubricant, grease etc near the float needle, it stops it sealing.rustybike wrote:If that don't cure it, it's going in the bin
Good Luck,
Carb has been stgripped, cleaned, tweeked and is back on. Atlast it seems ok. Had a quick test ride and goes as good as my other bike...
MOT booked for Monday... I hope it passes...
It passed.........
All taxed and tested.
Going for the frist propper shake down ride now.
I just wanted to say a big, Huge THANKS to all who have given great advice for the rebuild.
Massive thanks to Gronk for company and laughs. (he did help on the easy bits.. )
Can't wait for Stafford now.
Rus
thumbs up and well done to the chuckle brothers
Users browsing this forum: No registered users and 205 guests
