The build so far
digger
The build so far
Post by digger » Sun Nov 15, 2009 12:54 pm
Trying to build a bike using spares from the 350 and 500 does have its problems but as they occur I have to find a way round them.
I shall be relying on others ;) ;) ,( Apophis and Green machine) to help me with the mods that have to be made to a new 500 loom to incorporate the leccy boot circuit.It doesnt help matters when your,e colour blind either :roll: :roll: .
As I,ve only got a 500 rear wheel I,m contemplating using a twin leading shoe hydraulic conversion providing the 350 cylinder will do the job, which I need by the way, we,ll see.
More pics as it progress,s.
MT 500 "Inky" (short for incontinent), not now Minter,s sorted it :D :D
1936 Bsa R4
1961 Triumph Trophy
1966 Norton N15CS
1971 Laverda SF
Re: The build so far
Post by ZIP TIE » Sun Nov 15, 2009 3:13 pm
interesting, have you got an idea of a donor brake plate for this?
gordon
Post by gordon » Sun Nov 15, 2009 5:42 pm
Hi all,
that looks great, the engine looks good too, was it already painted or did you paint it, and if so what paint did you use,
cheers,
Andy
Post by Bunker » Sun Nov 15, 2009 5:47 pm
I can sort you a 350 rear wheel but it may be a little bent, could be sorted easily enough Im sure.
digger
Post by digger » Sun Nov 15, 2009 9:19 pm
I,m looking at several options at the moment but the easiest and most available will be a Morris minor backplate, early days yet.
The paint is UPOL hi build primer and Sperex satin bike black.
Simon thanks for the offer I,ll bear it in mind.
1936 Bsa R4
1961 Triumph Trophy
1966 Norton N15CS
1971 Laverda SF
Phatphil
Post by Phatphil » Mon Nov 16, 2009 10:31 am
Digger,
Why would you want a more powerfull,and complicated back brake ?
digger
Post by digger » Mon Nov 16, 2009 7:32 pm
Phatphil wrote:Digger,
Because there are one or two "minor" :roll: :roll: :roll: problems arising from combining the various parts that make the brake work, admittedly nothing that I couldnt overcome but as I,ve seen this conversion done before on a grimeca hub I thought I,d have a go. Tho it might come to nothing yet and I agree with you there,s nothing wrong with a well set up rear brake.
If the swing on my lathe was big enough, and the fact that Ive got a spare 350 caliper fork leg, I,d considered making a hub to take two discs but I thought it was a bit egotistical so thats a non starter :oops: :oops: :oops:
1936 Bsa R4
1961 Triumph Trophy
1966 Norton N15CS
1971 Laverda SF
Users browsing this forum: No registered users and 82 guests
