Ok heres my MT500 project, im still decideing exactly what i want to do, but fore most is more power and less weight.
Since its going to be faster it will need better brakes but i want to keep it all drums ive got this lovely TLS drum thats the stock one in the picture to give scale, it needs a little attention with the tig but it only cost Ă‚ÂŁ10!
and finaly in search of more power i just picked up this 604 head fitted with an 865 cam so that will give me bigger valves to go along with the lumpy cam.
next step for the engine is a 100mm omega piston which should get the capacity close to 600cc.
kick starin this thing is going to make a man out of me
project Blunt
Re: project Blunt
Cracking, a project to read about over the winter months.
Good luck with it fella
Daj
Daj
MT500e
MT500e
Re: project Blunt
cheers Daj im looking forward to getting stuck in with the plan to get it back on the road for spring so i can get some back to basics bikeing as my daily ride is a bmw k1100lt great in the witner and on the motorway but dull as ditch water any were else!
Re: project Blunt
it seems like a interesting project growing here, good choice of piston they are local to me and very reputable keep up the good work on the up and coming beast.
Re: project Blunt
Out of interest from someone who also needs a 100mm piston.
Do you have one sourced already? or are you buying new? (my understanding was that they only sell in batches of 3).
I also need the bore re-sleeving/finishing, do you have a contact?
All the best
All the best
Re: project Blunt
sorry no i dont, and yes ive also heard you can only get them in 3's from omega cost of Ă‚ÂŁ600, so i might have to find an alternative, think i read on here about some one useing a wiseco for a xr650, ive seen prox pistons for abouyt 120 for the xr, dont know if they require any mods to fit though.
Re: project Blunt
you can use the 97mm wiseco rotax piston. its a high compression piston so you have to make sure it can be used with cam you have and of the barrelcan be modified or not.
i think its about 120$
abdallah
abdallah
Users browsing this forum: No registered users and 221 guests
