MT350 speedometer drive
- jungleMTbiker
Anybody got a spare one? Alternatively, has anybody got a recommendation for one off of another bike that will work?
--1985 Armstrong MT500, was 05 KE 27. Installing 604E engine, better front brake and better rear shocks.
--Currently back in Papua New Guinea, left the bike hibernating in Surrey again
Re: MT350 speedometer drive
viewtopic.php?f=91&t=25436&p=231440#p231440
I still haven’t looked any further into this… but it was looking hopeful.
- jungleMTbiker
As I am using a Aprilia wheel, I think I've decided to use a Aprilia CEV speedo drive. I've also located a CEV drive that supposedly has the same gearing as the MT, but is in a cracked housing. If I get desperate I might pay the exorbitant price the seller wants for it just to steal the gears out of it for a different housing!
For me the question may end up shifting away from "what drive will I use?" to "What speedo will work properly with the drive I have?" If you are using a 21" wheel and a drive from a 21" wheel, then the speedometer that went with that drive will work. I'll try the original 500 speedo first.
Hi. I’ve had a few APRILIA Rotax type speedo drives with cracked housings, if not too bad you can strip, build up the crack with epoxy putty or similar then grease and rebuild. It’s always been a viable working repair. Nige.
- jungleMTbiker
Thanks, I wondered about that.
- jungleMTbiker
I now have a NOS original MT350 one.
Users browsing this forum: No registered users and 10 guests
