Engine stop
jensen
Engine stop
Post by jensen » Sat Dec 18, 2021 2:11 pm
The engine can start without the key and it will not stop. Is there any easy solution. SWM xn350 but it should be nearly the same as MT 350
Gbo
Re: Engine stop
Post by Gbo » Sat Dec 18, 2021 4:00 pm
It grounds a wire to the ignition unit to stop the engine. So either a broken wire to the switch from the chi box or from the switch to earth. Or the switch itself is not making contact.
jensen
Re: Engine stop
Post by jensen » Sun Dec 19, 2021 12:09 pm
I will check that again, but to me the problem looks like it is in the cdi box. If so...is there any other solution .
Re: Engine stop
Post by mt bandit » Fri Dec 24, 2021 2:11 pm
If it is the cdi, then its a replacement unit , I don't think you can repair them ,
Armstrong 600
500 outfit
