MT350 engine oil seals.
Docherty816
Post by Docherty816 » Fri Jul 01, 2016 12:07 pm
Hi, I am now knee deep in my MT 350 restoration and have removed the engine from the frame. My engine had an oil leak which I think was down to the NRV sticking open because the frame oil drained too. My question is now the engine is out, which engine oil seals should I change as a matter of course? Plus any other tips it advice would be appreciated.
Thanks, Mark.
AWJD
Re: MT350 engine oil seals.
Post by AWJD » Fri Jul 01, 2016 12:50 pm
To be absolutely confident, it's best to change all the oil seals if possible (crankshaft, kickstart, gearchange, etc) along with the neoprene seals on the rocker covers, cam belt cover, etc, and any sealing washers (engine drain screw, frame drain screw, etc).
Not absolutely sure why a sticking NRV should result in an oil leak unless it is due to a defective seal?
1996 Harley MT350e
1987 Armstrong MT560e
1997 Honda XR250R Ex-Army
1966 BSA B40WD
1971 BSA B50T
1973 BSA B50MX
P.I.STAKER
Post by P.I.STAKER » Fri Jul 01, 2016 1:34 pm
hi mark
i have replied to your message
cheers
George
ARMSTRONG MT500 1984
BMW R1100S
Docherty816
Post by Docherty816 » Sat Jul 02, 2016 4:07 pm
Hi George, thanks for the reply, Imbin a caravan in Devon and my internet is sporadic to say the least. Van you tell me how much its going to cost for all of the seals that can be replaced without splitting the cases?
Thanks, Mark.
P.I.STAKER
Post by P.I.STAKER » Sat Jul 02, 2016 4:48 pm
hi mark
i have sent you a pm, with what i think you may need.
cheers
George
BMW R1100S
WJP
Post by WJP » Sat Jul 02, 2016 5:00 pm
Hi Mark
I see that your in Oxford. If you have already taken the engine out why not take it for a check up by Gary at Sportax. Your less than 20 miles away, just down the A420.
Cheers
Will
Therapy 1 Desert 350
Therapy 2 Green 604
Canam 250 Green/Rust camo with Blue smoke screen
1959 Police stealth bike, Grey 7 bhp and 6 volt pos earth
Two MTs in Canada now Sold :cry:
Latest project (challenge) BSA WM20. Oil incontinent and missing parts!
Docherty816
Post by Docherty816 » Mon Jul 04, 2016 7:44 pm
Hi Will, the engine was running great before I started the strip down, apart from the oil leak. Plus I want to do as much of the mechanicals myself if I can. The engine is out primarily to get it repainted as its corroded and a bit tatty. While its out I wanted to replace any seals that I can to future proof it. I'm struggling to find somewhere locally to strip and paint it though.
Cheers, Mark.
Docherty816
Post by Docherty816 » Mon Jul 04, 2016 9:08 pm
Hi George, I got the message but was wandering whether you could supply them to me and if so how much would it be?
Cheers, Mark
WJP
Post by WJP » Mon Jul 04, 2016 9:51 pm
Hi Mark
Going a bit off topic here (apologies to the mods) but in answer to your question about engine prep and local companies. For my rebuilds I have used Oxford Fine Finishing for the frame and steel parts, but when I took some rear shock springs in for blasting and powder coating a few weeks ago, the owner Jack (top bloke) has sold the business and its now linked to a car body repair shop and I put the service I got down to a management transition. They do a lot of industrial stuff and tend to use a hard blast medium so I have never risked an engine after the first time I got them to blast and coat the lower part of the front forks and yokes. Kev (Moose) used a place down in Newbury but again just for the frame for his desert 500.
As far as the engines go I have either stripped them down and sent them to a specialist in Bristol, via Sportax, to be powder coated as separate parts. They use the correct medium for the soft alloy cases, blank the surfaces and do a great job, but not the cheapest option. This should take you to one of my rebuild links so you can get an idea of the work needed for this option
http://www.mtridersclub.co.uk/viewtopic ... it=Therapy
I once bought a 350 engine that had been blasted and powder coated in its entirety from a show bike that was being broken. That was stripped and a lot of blast media had found its way inside and the act of separating the parts cracked and ruined the coating, glad I didn't pay much for it, but whatever you do dont let anybody blast the entire lump. Sounds obvious but I have the proof that somebody did it.
On some of the bikes I have done, if you dont want to strip the engine into its component parts stick with de greasing, various sizes of wire brushes and lots of elbow grease. Lots of paint options available that claim to be high temp etc. I have had good success with specialist brake caliper paint as this is rated to about 150C and is reasonably chemical resistant once fully cured (several days). If you use the forum search facility there is a lot of discussion about engine paint options.
Drop me a PM with you contact details and we can have a chat
Cheers
Will
Therapy 2 Green 604
Post by Mr Shiney » Tue Jul 05, 2016 8:05 am
I had my 604 engine overhauled by Minter and it is a work of art. He used a company that vapour blast and powder coat at a very reasonable rate. My engine is like brand new and I had a custom Sportax "Works" colour scheme on it. You can see see the before and after on my last restoration thread.
Users browsing this forum: No registered users and 74 guests
