new project
Re: new project
What's the plan with this one then Dave?
Re: new project
I like the front end, however not sure about the fairing/screen affair!
Each to his own
Each to his own
Re: new project
thought i would try to make a road/trail bike something that would tour a bit more relaxed but still be capable off road [its evolving as i build it ] up to now it has ccm upside forks, big brembo brake inc master cylinder,magura fat bars, 604 engine which by luck has a 670 cam so hopefully safe,kehin 41mm fcr carb, pro curcuit sillencer, rally raid ktm 690 dakar front and sides fairing with front light upgrade which has taken ages to fit, still lots to doMinter wrote:What's the plan with this one then Dave?
a few picks of fairing headlamp bracket design .
Re: new project
No offence meant I thought it was two bikes that had been put together with Photoshop to see if anyone would notice
Re: new project
Nice Work, What did you use to support the Fairing, it looks like you used Ply to start off then it changes to a different material, or is it ply that has been painted?
Ta,
Ta,
Re: new project
yes arry,ply to make the patterns then plastic chopping board [read about using this on one of the adventure bike forums] as its very tough and cheap riveted together with ally angle. stainless threaded bar with plastic central heating pipe over between as its a fixed fairing the steering has less weight so less rider fatigue in theory.
hey englishman hopefully look better once all the same colour
Re: new project
I am sure it will. I look forward to seeing the finish job and good luck with the remainder of the project.
Re: new project
What an intriguing project, ill follow with interest
Users browsing this forum: No registered users and 213 guests
