From the ashes
From the ashes
The fire damaged MT350 has returned from the Exeter Trial and has been stripped and soon it will be going to the paint shop following blasting.
The stripping wasn't too difficult, well all the plastics were destroyed by the fire. The frame looks pretty straight, with no visible cracks, it seems quite sturdy. I'm sure these bikes were designed for a tough life in the Army. The bearing in the swing arm took a bit of effort to get out and I spent an age getting the dipstick out of the frame. At one stage I was lying on my back with the thing on top of me, wriggling it about like I was wrestling it. It took a barbecue fork to spear it and bring it to the neck and a screwdriver to prise it out.
There was a lot of surface rust and more deeper corrosion that was probably lurking there before the fire. If I can get the frame powder coated it will be a big morale boost.
Re: From the ashes
Wow
Good luck im glad you have decided to rebuild it.
Must have got incredibly hot looking at the rear wheel rim and the handlebar clamps!
Re: From the ashes
Hi Sam
so glad you are going for the rebuild route
it would have been a shame to lose this bike
it will be nice to follow the rebuild as it takes shape
all the best Paul
all the best Paul
Re: From the ashes
good luck with the rebuild, i was marshaling the exeter at rill path the closing car told us there'd been a bike fire didn't know it was a mt until i got home i've got the headlight plastics you can have all the best see you on the hills
Re: From the ashes
rising from the ashes, all the best to you trifire
http://youtu.be/67xXbTaQlKI" onclick="window.open(this.href);return false;
Re: From the ashes
Keep going. It will be worthwhile and I wish you every success. Make sure you do not get any MT promises.
Re: From the ashes
Did you try heating it up?trifire wrote: The bearing in the swing arm took a bit of effort to get out
Good luck with the renovation, it's good to see it's not dead.
Re: From the ashes
Yes, it wasn't too difficult. I suppose with the rest coming apart easy it just seemed to take a long time.ellrider wrote:Did you try heating it up?trifire wrote: The bearing in the swing arm took a bit of effort to get out
Re: From the ashes
Progress has been slow with other commitments. I missed the deadline for the frame blasting but the swing arm needed a bid of work doing to it anyway. The centre stand stop bracket was bent, I think thats why the side stand and centre stand were rubbing against each other making an occasional annoying squeak whilst riding along. Following adjustments it broke away from the swing arm. I will weld this back on, I may put it back so I get the squeak, just to remind me that its still the same bike!
The engine has had a bit of a clean down, there is damage to the generator. I haven't managed to get this off yet, but its definitely knackered. Could the cover be stuck to all the melted wire inside ?
I hope to do a bit more this weekend and post some more photos.
- arceye
Re: From the ashes
Best of luck with this.
Any chance you can post normal size, its a pain moving the page side to side to read it.
Users browsing this forum: No registered users and 202 guests
