MT Pockets 560 Gearbox Rebuild
Ady has battled throught the snow so we can pull apart his Aprillia 560... It was a bit of bargain off ebay but the final drive sprocket had been welded on! What lay inside then we wondered!
Well here it is in the flesh, again the differences within this engine are quite a bit compared to our MT varient..
Clutch basket looks the same from the outside but has springs built in the basket, probably to make a smoother action?..
Note the rev counter drive on the kickstart shaft..
Even this gear has the springs within..
Cylinder in V good condition, few scores on piston but still perfect fit in Cylinder, rings just inside tolernce but going to replace them all anyway..
Flywheel has a huge extra weight on it..
Swap all gears on centre shaft to new shaft on the right.. Simples!!
All ready to piece back the 2 halves now..
- ZIP TIE
Re: MT Pockets 560 Gearbox Rebuild
If you take the flywheel off can you measure the weight for width, diameter and pcd of mounting bolts as when I was telling Alex(throb) about them he seemed quite interested in trying one to see if it reduced his stalling/lumpy tick over issues and he may want to knock one up
No probs Steve, its got to come off any way as it pulled the crank out the RH case by 2mm when seperating the cases, so it'll have to be pulled back in to re seat on the mains..
Gary, is there a Nicasil bore on this motor or liner?
Ta, Mark.
Ta, Mark.
Hi Mark, Yep its a nicasil plated cylinder..
i would be interested in that too.ZIP TIE wrote:If you take the flywheel off can you measure the weight for width, diameter and pcd of mounting bolts as when I was telling Alex(throb) about them he seemed quite interested in trying one to see if it reduced his stalling/lumpy tick over issues and he may want to knock one up
Further 560 clutch reading: http://forum.mtridersclub.co.uk/viewtop ... 39&t=12439
Yep i remember that one, Ady's came apart fine though.. Out of all the different motors seen i reckon aprilia motors have the highest spec..Bunker wrote:Further 560 clutch reading: http://forum.mtridersclub.co.uk/viewtop ... 39&t=12439
Im sure all the specs were available to the MOD but they probably slimmed it down a littleOut of all the different motors seen i reckon aprilia motors have the highest spec..
Users browsing this forum: No registered users and 77 guests
