Armstrong rebuild continues......
ourkid
Post by ourkid » Thu May 17, 2012 7:09 pm
;) After too many weeks off the project, i got my arse into gear again this week.(think my estimate of on the road for Easter was a bit optimistic, sorry Eric :D
The bearings for my motor are due to arrive tomorrow,managed to get the whole lot (replacing everything), for £90
I had a go at seperating my spare crank, had to make a jig to hold it whilst giving it 15 tonnes :shock: .The side shims on my original crank were missing and you can see from the pic that the roller cage has took a hammering.The other crank i intend to use will be setup by a local bike Engineer for a very reasonable £30.
The bore was stained but came up fine with a glaze buster.Luckily there is no wear on the bore or rings but i got another piston as the small end was battered.
The cases took best part of a week to strip ready for paint (i don't like using shotblast on engine parts so it came down to chemical stripper,rotary wire brush,scraper and loads of patience ;)
pleased with home made headlamp guard - looks the part!
Can't figure out how the sidestand spring fits - surely this is miles too short ?? - the furry stuff is the dog helping me out btw :lol:
Re: Armstrong rebuild continues......
Post by ZIP TIE » Thu May 17, 2012 7:16 pm
Cases look nice like that but would end up furry very quickly.
Liking the mounting solution for the lamp guard :D
ourkid
Post by ourkid » Thu May 17, 2012 7:20 pm
ZIP TIE wrote:Cases look nice like that but would end up furry very quickly.
thanks mate - the cases will be painted black! - not sure a Armstrong would suit a polished motor :lol:
Post by Wirralman » Thu May 17, 2012 7:27 pm
That spring looks like an MT350 centre stand spring. I'm sure someone will advise shortly. I'll have a search , there have been pictures posted showing MT500 sidestands left and right
Eric
PS I know you've been busy with your cars
Post by ZIP TIE » Thu May 17, 2012 7:29 pm
how about polished billet machined cases :P
The spring should be the same as the centre stand ones like the one you've got but with a long straight piece between the coil and hook.
ourkid
Post by ourkid » Thu May 17, 2012 7:39 pm
NICE!!
Yeah, it's a 350 centre stand spring that i bought (was told it would fit).What you said makes sense , as Eric said, hopefully i can find a pic to help me out ;)
Rick900
Post by Rick900 » Thu May 17, 2012 7:51 pm
Just nipped out to the garage & took these, hope it helps :)
Image Image
Post by ZIP TIE » Thu May 17, 2012 7:52 pm
ourkid
Post by ourkid » Thu May 17, 2012 7:54 pm
Thanks guys!!!!!!
Any idea who sells em???
Post by ZIP TIE » Thu May 17, 2012 7:57 pm
£8.50 LMS
Users browsing this forum: No registered users and 32 guests
