Cleaning out frame for powder coating
Ready now to get the frame powder coated but want to flust oil out fo frame before whats the best product to use?
Re: Cleaning out frame for powder coating
I bought a degreaser from Autoparts in Folkestone a gallon can and is very potent stuff. If you get the frame warm the most of the oil will run out. I would use a hot air gun 1st to remove as much as possible 1st.
Good Luck,
Good Luck,
when i done mine i just put a pint of petrol in and gave it a shake then let it drain into an old oil can for recycling
Users browsing this forum: No registered users and 249 guests
