Nut and Bolt Rebuild on Emma
Re: Nut and Bolt Rebuild on Emma
- Attachments
- 23102009028a.jpg (34.98 KiB) Viewed 1008 times
- 23102009027a.jpg (36.18 KiB) Viewed 1006 times
- 23102009026a.jpg (34.5 KiB) Viewed 1009 times
- 23102009025a.jpg (42.93 KiB) Viewed 1207 times
looks triffic mate
How will it clear the rear tyre sidewall without the original flattened section ?
the rear can clears the side wall Via Straight edge it is about 10mm away and the exhaust was taken up out the way as well as you can see in the pic
it has all been measured to not be in the way at all
wife took this pic with her crapy phone so i thought i would also add it sorry for the quality
- Attachments
- 2009-10-23 20.16.56.jpg (56.32 KiB) Viewed 962 times
Have you given him the nod to start mine yet Craig??.
1936 Bsa R4
1961 Triumph Trophy
1966 Norton N15CS
1971 Laverda SF
1936 Bsa R4
1961 Triumph Trophy
1966 Norton N15CS
1971 Laverda SF
noticed the pannier mount on the near side is back to front, you have the tie bar mount facing forward.
nice spot on that but it is only there for the Exhaust guy to make the exhaust up
I havnt done fitting the Frames in the DVD yet so it is all coming off again
if you look realy close you could also catch there is only 3 Fixings holding the front disk on as well
the exhaust you have... can that be fitted with all the pannier stuff inplace, does it follow the old routes etc.
Im liking that and Might be interested down the line when the 350 unit bites the bullet
it will indeed fit it has been done so that it is more or less the same as the original
so there are headers, center section then a riser section to slip a rear can of your choice on
I am also having it done so this can be made out of the same bore as the original 350
for headers and center section
the last section is going to also be made so it will slip onto the original mid section
for the 350 and the 500
Users browsing this forum: No registered users and 23 guests
