Full Flow Stainless Exhaust Link Pipe
Re: Full Flow Stainless Exhaust Link Pipe
Thanks Kev
- BikingBodger
After my experience, this weekend, I thought it might be worth suggesting others check their link pipes.
My mate spotted my silencer waving about. When I stopped I found that the hanger had shears and that the link pipe had come away from it's mounting bracket. I assumed that the hanger had broken first, and that the weight of the silencer had caused the link pipe brackets to break. However, when I took it all apart I found that the broken welds on the link pipe were encrusted in muck, so had been broken for some time. You might want to check your link pipe.
I'm not sure whether to get the link pipe mounting bracket welded back on, or whether to try and mount it with a "P" clamp. Any suggestions?
Cheers,
Kit
1976 BMW R90/6
1994 MT500e 26KL01
1998 Cagiva 900ie Gran Canyon
Kit
1976 BMW R90/6
1994 MT500e 26KL01
Hi Chris,BikingBodger wrote:After my experience, this weekend, I thought it might be worth suggesting others check their link pipes.
This is the first time ive heard of this. The pipes have a lifetime guarentee. If you return it i will have it repaired and refund your shipping costs
Regards
- BikingBodger
Thanks Garry, I hadn't realised you'd guaranteed the link pipe.
I didn't post my comments as a complaint; after all the exhaust hanger sheared too. I thought I ought to warn others as with the exhaust hanger broken as well as the link pipe mounting, the whole weight of the exhaust system was bearing on the two manifold clamps........... which could lead to costly damage to the head.
Cheers,
Cheers,
Cheers,
Kit
1976 BMW R90/6
1994 MT500e 26KL01
Kit
1976 BMW R90/6
1994 MT500e 26KL01
I just spoke to Martin at MTC exhausts. Really helpful guy. They now do standard 45mm inlets for CCM (and Minter's linking pipe) Apparently they didn't used to. I have ordered a black oval with a carbon end -apparently only marginally heavier than a iull titanium with SS end. I'll post a piccie once fitted.
Good news Guy, Link pipes should be done by the end of the week..Guido64 wrote:I just spoke to Martin at MTC exhausts. Really helpful guy. They now do standard 45mm inlets for CCM (and Minter's linking pipe) Apparently they didn't used to. I have ordered a black oval with a carbon end -apparently only marginally heavier than a iull titanium with SS end. I'll post a piccie once fitted.
Chris your repaired bracket link pipe was posted out first class signed for this morning..
Hi Guido64
I'm in the process of deciding on exhaust for current project that will replace the 350 with a 500e that Gary built for me. I like your choice and was wondering if you had fitted it yet and could share a few piccies.
Can you put me down for a link pipe please, no rush as I doubt I will be ready to install it before starting next round.
Cheers
Will
No probs Will.. I've stainless and ti mtc cans on the shelf if you wanted to see them in the flesh so to speak..
Thanks Gary, I'll call in to take a look. Will call you re date and time as I think Bunker has some panniers for me to look at as well. I will bring the biscuits
Nice One! Simon is coming up for a 'workshop wednesday' tomorrow evening all being well.. try and combine the two....WJP wrote:Thanks Gary, I'll call in to take a look. Will call you re date and time as I think Bunker has some panniers for me to look at as well. I will bring the biscuits
