Yes the cheaper the better.bth2bth2 wrote:i take it your only buying a very small can of spray???
Now where did I put that???
Re: Now where did I put that???
Yep i remember thinking to myself if any one can see me now... as i walked around the garden shaking a petrol tank!!rustybike wrote: Gary, I should have used POR15 before I had it painted. When Gronk did his there was a whole lota shaking going on..
I have got a bit more done today.
I have cleaned and primed the petrol tank again. I just need to check that the leak has been sealed. Then I can repaint it.
Also my new reg/rec arrived.
I have reused the connectors because the fitted wires are a bit on the short side. Only took me 15 mins.
I connected it up to the bike and it was holding a steady 14.8v. I am going to make a stainless steel mounting bracket so that I can keep the original mounting holes.
I am getting there
I am getting there
Next few bits done today.
The brakes are all done, new pads, seals, pins and all bled.
Chain and sprockets fitted and adjusted.
And the worlds most anoying job done tooo, fitting the center stand springs...
Just the tank and reg/rec to sort, then I can book it in for its MOT....
WOOOHOOO, and then there'll be no stopping youJust the tank and reg/rec to sort, then I can book it in for its MOT....
- ZIP TIE
Yeah double check your brakes!Wirralman wrote:WOOOHOOO, and then there'll be no stopping youJust the tank and reg/rec to sort, then I can book it in for its MOT....
rustybike wrote:I have got a bit more done today.
I am getting there
is that the reg/rect I suggested a few weeks back @25?
Eric, Zip, There better some stopping of me or else it will be a big waste of effort. Oh and money...
Yep it is Freddy. Good spot by you. I just want to make a bracket to mount it, because I don't want to drill the head light cowl. Also I can bring the wires underneath the unit without it being pressed up against the underside the cowl.freddy54 wrote:rustybike wrote:I have got a bit more done today.
I am getting there
ok , glad you are happy , now somebody find me a new clutch cheap!
Have had it running today, but the headers were glowing cherry red. Had the mixture screw set from 1 1/2 to 3 turns out. Rechecked valve clearances and timing. Going to change the carb to manifold rubber tomorrow. Is there anything else to check?
Users browsing this forum: No registered users and 223 guests
