Ben's MT350 Rebuild
neoxerox
Re: Ben's MT350 Rebuild
Post by neoxerox » Sun Dec 18, 2011 11:50 am
I'm back in Leicester with my garage again now so the rebuild shall resume! Hurrah!
SKAGS MCC
Post by SKAGS MCC » Sun Dec 18, 2011 1:39 pm
You're doing such a great job, want to do mine ;) Cheers. Vinnie
neoxerox
Post by neoxerox » Wed Jan 04, 2012 5:46 pm
Right after all the faff trying to get my unidentifiable frame sorted I've just gone and got another, this time complete with a real VIN and 654 - got a sense of dejavu at the moment though as I'm prepping the second frame for paint...
Pictures and finally some more re-building to follow :)
neoxerox
Post by neoxerox » Thu Jan 05, 2012 12:10 am
Frame after 1 coat
Forks after aluminium primer - tomorrow i'll put the topcoat on
Crazy aluminium primer - in real life it's electric blue but this camera's sh*t....
Swingarm after 1 coat
Tomorrow the plan is to put another coat on everything and get the dash/headlight cowling plastic stripped. The original speedo is nackered so i'm looking to put a new digital speedo in - maybe a trailtech vapour or vector - mounted in an alu plate with the original information lights & ignition key.
Am I right in thinking that an Aprilia RS50 digital speedo pickup fits as a direct replacement for the mechanical pickup on an MT350 front end? I saw it in a digital speedo thread but don't recall anyone confirming it. Also, can anyone comment if it can provide a suitable input for a trailtech or similar instead of the individual magnet/sensor?
neoxerox
Post by neoxerox » Fri Jan 06, 2012 6:15 pm
The building back up has finally started - though probably a little pre-maturely.
Anyway - Engine, underguard and front frame
With main chassis
With forks :D
Finished the last of the plastic stripping too today. Tomorrow will be getting the swing arm and wheels on so that it's mobile enough to be moved about the garage before I leave again.
SKAGS MCC
Post by SKAGS MCC » Sun Feb 12, 2012 6:19 pm
Hi Ben, glad you got all the frame probs sorted mate. Looking forward to the next installment. May even come up and see it in the flesh in next few months if about, and mine makes it that far lol. Not had mine on a long run as yet, but will do Stafford this year. Keep the good work up mate. Speak soon. Cheers. Vinnie
neoxerox
Post by neoxerox » Sun Feb 12, 2012 8:35 pm
Cheers Vinnie!
Should be something in the coming weeks regarding electrics/the dash but there won't be anything else till i'm back on the build proper over Easter.
neoxerox
Post by neoxerox » Tue Feb 21, 2012 11:30 pm
So here's the dash plate nearly finished, just need to add on the speedo support tags (once i figure out the sheetmetal function in solidworks properly), then it's off to be laser cut from some 2mm 6082-T6 aluminium :)
Space for a Vapor speedo, the key barrel, the standard lights and a 12V power socket
Just not sure whether to leave it bare alu or have it anodised black...
neoxerox
Post by neoxerox » Fri Mar 30, 2012 5:39 pm
The dash plates been laser cut and is currently at the anodisers (sorry didn't get an inbetween pic but it looks sweet) for a black coating.
The bike is now packed up ready to come back to uni with me so hopefully progress will be visible as I procrastinate from revising for my final exams!
neoxerox
Post by neoxerox » Mon Apr 23, 2012 3:21 pm
Finally got round to doing a little, replaced the front and rear wheel bearings today but found I needed to do the sprocket bearings too. They're on order now so the wheels should be on next week.
Users browsing this forum: No registered users and 197 guests
