Madstu's Minter Rebuild!
MadStu
Re: Madstu's Minter Rebuild!
Post by MadStu » Mon Aug 20, 2012 10:42 pm
Minter said it doesn't work even with holding the wires together, so it's something other than the switch itself it seems.
If it's only a failure if the switch is present, then just remove the switch and hide the wire ;)
HD MT604e - THE WUF
Armstrong MT405e - THE CNS
Roey
Post by Roey » Mon Aug 20, 2012 10:46 pm
MadStu wrote:Minter said it doesn't work even with holding the wires together, so it's something other than the switch itself it seems.
That's what I meant ;)
No problem, thank you
Post by ZIP TIE » Mon Aug 20, 2012 11:06 pm
Stop lamps may operate in conjunction with either the front or the rear brake, or both. On machines first used on or after 1 April 1986, the stop lamps must operate by the application of each system.
http://www.ukmot.com/bike_1-3.asp#Text_top" onclick="window.open(this.href);return false;
Post by Minter » Tue Aug 21, 2012 6:25 am
ZIP TIE wrote:Stop lamps may operate in conjunction with either the front or the rear brake, or both. On machines first used on or after 1 April 1986, the stop lamps must operate by the application of each system.
Cheers Zip! Now ill have to get it sorted just to be on the safe side! Not that Stu uses them! Have you seen his BMW brake failure vid!!
Post by Minter » Wed Aug 22, 2012 7:55 pm
Bottom end all done now, Just the top end to stick back on now...
MadStu
Post by MadStu » Wed Aug 22, 2012 10:11 pm
Oooh that looks painful! :O Thanks for all your hard work mate :)
HD MT604e - THE WUF
Post by Minter » Wed Aug 22, 2012 10:24 pm
MadStu wrote:Oooh that looks painful! :O Thanks for all your hard work mate :)
:lol: No probs mate! That'll be my cylinder honeing tool! Its fine when you get it in!! ;)
MadStu
Post by MadStu » Thu Aug 23, 2012 8:22 am
That's what I told my girlfriend!
HD MT604e - THE WUF
Post by Minter » Thu Aug 23, 2012 6:54 pm
MadStu wrote:That's what I told my girlfriend!
:lol:
Motor now finished! Heres some pics of the top end going back on....
Head all de coked and valves lapped back in and new stem seals...
Glad Mike, John and Ruth are calling in tomorrow to help me lift it back into the frame!
Users browsing this forum: No registered users and 207 guests
