12royal
Post by 12royal » Fri Sep 30, 2022 11:52 am
Been for the MoT today, passed with no addys. :D. A quick bImble around Derbyshire and back home for bacon cobs with brown sauce .
Thanks to Eric, Nick at Force and Gary at Sportax for the spares bought this last year.
Regards to all, Alan
Post by Wirralman » Fri Sep 30, 2022 12:13 pm
12royal wrote: ↑
Good to here of your MOT, hopefully you got home before the rain :D
bigfatcat
Post by bigfatcat » Sat Nov 05, 2022 6:45 pm
Rolled it out the garage after having not used it during summer (when my TT600 takes over) and it starting up fine then passing it's MOT first time. Advised on front wheel bearings, just a little play, so will need to see if they are a standard bearing, should be easy. Should be.
MT500
Triumph TT600
BSA B40 Trials
Kawasaki Z200
Velosolex 1700
Honda P50 and PA50
Post by lardmarc » Sat Nov 05, 2022 6:56 pm
bigfatcat wrote: ↑
Should be easy.
6204 2RS x 2
A doddle.
Post by Wirralman » Sat Nov 05, 2022 7:19 pm
lardmarc wrote: ↑
bigfatcat wrote: ↑
Should be easy.
6204 2RS x 2
A doddle.
Totally agree. Changing the rear is a little harder but well worth it. It might not feel any different to ride, but something to do over winter to avoid an MOT failure
bigfatcat
Post by bigfatcat » Sat Nov 05, 2022 8:08 pm
cheers for the info, did the rears 5 yrs ago, doubled bearings if i recall, they're still fine but i don't deep ford it these days
MT500
Triumph TT600
BSA B40 Trials
Kawasaki Z200
Velosolex 1700
Honda P50 and PA50
Post by Wirralman » Sat Nov 05, 2022 9:31 pm
bigfatcat wrote: ↑
Yes twin bearings at the rear either side- ex-factory the inner bearings didn't have seals if I remember correctly. The sprocket carrier has 3 bearings on the MT350- think the MT500 only has 2.
If you've changed the rear bearings you'll find the front as Lardmarc describes- a doddle.
Post by Laurence » Wed Jan 10, 2024 10:18 pm
A light dusting this week..
Dave
Post by Dave » Thu Jan 11, 2024 7:28 pm
Removed / disconnected every thing required off my MT500 to drop my engine out in the morning. Then head and barrel off tomorrow to find a solution to stop it burning oil. Must be either Valve stem seals or piston ring. Boy these machines are quirky.
jam23a30
Post by jam23a30 » Sun Jan 14, 2024 10:07 am
Just on the same mission to remove the head. Mine doesn't burn oil noticeably but compression is low so guess valves aren't seating or some such,time will tell.
I have had a right royal battle removing the exhaust studs and splitting the original exhaust system but just about there now with just the original trouser guard screws to get out. Crank nut and cam pulley bolt are now loose so next step is to drop the engine and take peek inside.
Keep us posted please on what you find to be the problem, it would be interesting to know as I'm new to the MT too!
Andy
Users browsing this forum: No registered users and 18 guests
