Vtrsp1da
Post by Vtrsp1da » Mon Oct 04, 2021 7:06 pm
lardmarc wrote: ↑
Mon Oct 04, 2021 7:04 pm
Vtrsp1da wrote: ↑
Mon Oct 04, 2021 6:19 pm
How much were they?
Reasonably priced. Once they're gone we're stuffed. I'm making sure I've got enough to rebuild a couple of MTs and a Sheffield parks CV500, if I ever get around to it.
https://www.forcemotorcycles.com/collec ... p-assembly
How much now I know you need help
Post by deadgrass. » Mon Oct 04, 2021 7:40 pm
Vtrsp1da wrote: ↑
lardmarc wrote: ↑
Vtrsp1da wrote: ↑
How much were they?
I think i might just have to paint me arse red,
Post by lardmarc » Mon Oct 04, 2021 10:13 pm
Vtrsp1da wrote: ↑
How much?
You'd pay that much for a nos Triumph or BSA part but not for Armstrong parts.
Shiney was right, light bulb repairers.
NeilM
Post by NeilM » Tue Nov 09, 2021 9:26 pm
Got the MT500 through another MOT.
Also, got told why there is oil leaking from the clutch cable... so that's a job for tomorrow.
NeilM
Post by NeilM » Wed Nov 10, 2021 3:37 pm
The MT has recently developed an oil leak from the point where the clutch cable leaves the engine.
I was reliably informed on the MT FB group that there is an O ring on the fitting at the end of the clutch cable, this turned out to be the source of the leak.
Fist thing was to work out how to get the cable out. Following a few posts on this very forum it only took a few minutes to realise that the slot in the clutch arm is on one side, not at the front as I had imagined. Once I figured that out, my paperclip special tool did its thing in moments.
The O ring fitted to the cable end seemed a little small for the job, plus I had nothing the right size so I found something slightly larger in all dimensions, persuaded it into place and slid it all back in the hole (Phnar!).
I have done a quick whizz round the block, but didn't realise it's school out time, so another run will be needed to be sure, but there is certainly no sign of a leak now.
Post by lardmarc » Wed Nov 10, 2021 3:59 pm
NeilM wrote: ↑
The slot in the clutch arm is on one side, not at the front as I had imagined.
It's not a slot, It's a loop.
https://www.youtube.com/watch?v=Liu3JQ6P5q4
Post by Wirralman » Wed Nov 10, 2021 4:23 pm
Well done NeilM, glad the paperclip helped you guide the cable out and into its slot.
Hopefully your oil leak will be a thing of the past. Be sure to check the oil level after you've run the engine for five minutes. If it is overfull , it will still leak. I used to run about halfway between min and max
NeilM
Post by NeilM » Thu Nov 11, 2021 5:15 pm
lardmarc wrote: ↑
I could be wrong, but the arm on mine didn't look like that one. That looks like a flat blade that has been bent back on itself, mine has more of a cup at the end and has a definite slot cut into one side.
I should mention that my engine is from an MZ, so it may be different.
Wirralman:
When I first bought my 500 it had freshly been 'enthusiastically' filled with oil. It took a while to trace the leaks back to the top of the frame. This time around I filled it cold until the oil just touched the bottom of the dipstick, this seems to bring the level up to just over half way when hot. Which is just as well, because that was all the suitable 20-50 oil I had. :D
Post by lardmarc » Thu Nov 11, 2021 5:35 pm
NeilM wrote: ↑
The arm on mine didn't look like that one.
350's, Aprilia and some others have a cast alloy clutch release cam. Still just as easy to get the clutch cable into it unless you have Parkinsons or hypothermia.
NeilM
Post by NeilM » Thu Nov 11, 2021 5:55 pm
That may well be what is fitted to mine.
Wiggling the cable to get it loose, while laying on the floor of my garage, I can just imagine how much fun changing a clutch cable at this time of year in a nice wet, muddy green lane would be.
Users browsing this forum: No registered users and 10 guests
