TDI Powers 350 Engine Rebuild
Re: TDI Powers 350 Engine Rebuild
Post by appyarry » Sat Feb 23, 2013 5:49 pm
TDIPower wrote:It has just taken me 2 solid days just to cut my hedge and I only cut through the power cable once! I still need to clear up all the cuttings. Pete
You need to buy a wife! Lots to choose from, mine never cuts the cable and always tidy up afterwards.
Post by TDIPower » Sat Feb 23, 2013 5:52 pm
I have a wife and I didnt even have to buy her!! she's great round the house and italian so food is brilliant, the down side at the moment is she has a bun in the oven so has to keep resting.
Green Goblin
Post by Green Goblin » Sat Feb 23, 2013 6:37 pm
TDIPower wrote:
It has just taken me 2 solid days just to cut my hedge and I only cut through the power cable once! I still need to clear up all the cuttings. I have taken 2 ft off the width on my side and 3 off the top and its still 3ft wide and 8ft tall
Hedge + Land Rover = no hedge to cut any more
Post by Minter » Sun Feb 24, 2013 10:20 pm
Almost finished!
Georges valve spring compressor makes light work of refitting the cleaned, polished and reground valves..
Then 4 coats of paint...
Already to put back together with a new piston kit
Piston slid into cylinder with ring compressor then fitted over dowels to connect the gudgeon pin and circlips
Polished head and new o rings next.. and the remainder of Georges stainless nut and bolt kit!
Almost done
Just the starter motor and timing gear and a 6 minute run on the test bed..
Post by Minter » Mon Feb 25, 2013 9:32 pm
All back together, just need to fire it up - but at a more sociable hour!
Post by TDIPower » Mon Feb 25, 2013 11:15 pm
meant to ask but as you know been somewhat distracted with life...
What was the state of the sprag, cam pulley (i know the lower had a few marks, I had 'skimmed it' myself as much as I dare) and the cam belt rollers bearings?
Did i keep the kick as well as the gear select? I know I took something off for ease of transit?
Post by Minter » Tue Feb 26, 2013 10:44 am
TDIPower wrote:meant to ask but as you know been somewhat distracted with life...
G'day Pete,
Sprag OK Top Pulley OK timing bearings U/S and replaced. I have the kick start, Ive treated it to a lick of paint..
Post by Minter » Wed Mar 13, 2013 10:14 pm
Petes Engine ran on the test bed tonight assisted by these two paasing by! Anyone recognise them!.....
Motor ran well and as it should and is now on its way back to Barnsley as i type!
Post by Wirralman » Wed Mar 13, 2013 10:17 pm
They both look dodgy to me :lol: :lol:
Post by ellrider » Wed Mar 13, 2013 10:18 pm
Arkwright and Granville???
Users browsing this forum: No registered users and 71 guests
