Fixed my first problem today, brake light was responding to front lever intermittently, then stopped working altogether yesterday. Switch itself tested OK. Eventually found one of the wires broken, inside the loom by the headstock. I think my multimeter may see plenty of action with this bike.
Also took the opportunity to clean and grease the earth points.
MOT passed!
Also need to try and change oil with out coating my self this time
Oil and filters changed,that's it for this year.
Hal
Hal
One MT Teeshirt No 4 should enough for anyone (I 've got a few)
Replaced the seat cover with a new one from Wild Extreme, fitted perfectly and straightforward to do. Looks good!
Went out road riding over the weekend and went along to the Ace Cafe Brighton Burn Up on the sea front. Covered 300km!
Replaced clutch cable today, clutch a lot smoother now!
Hal
Hal
If your old cable is still serviceable leave it routed in with the ends taped up You then have a get-you-home spare you can fit in a trice should your new cable fail (they fail with no warning at the handlebar end)highland al wrote: ↑Fri Sep 14, 2018 2:54 pmReplaced clutch cable today, clutch a lot smoother now!
Hal
This week has been mainly about keeping my Dad busy on the Dakar-Tourer MT600 project!
This is just a dry build stage before a complete strip down, blue treatment and a go faster, smoooooth motor!
Users browsing this forum: No registered users and 28 guests
