cant remember on the 500 but its a bit off on the 350 and i fit my rubber the same way.
MT500 - Rebuild
Re: MT500 - Rebuild
My 500s the same -- off centre, & I have to fit the rubber the same way. Not easy is it
Where do you get new rubbers from?
Ron
Ron
1986 MT 500
Ariel Red Hunter.
GL 500. x4.
Yamaha 1100.
Ariel Red Hunter.
GL 500. x4.
Yamaha 1100.
Re: MT500 - Rebuild
She runs, my electircs work !! I do need to adjust the clutch and the idle speed though.
The carb was overflowing at first so I took the bowl off with much effort, I resorted to choping the handle off one of my cheap screwdrivers to get the screws out!
I attached the bowl and float to the tank, turned on hte petrol and it all worked fine, typical! Must have been dirt that got in during the rebuild, although I take extra care to keep it clean .
Put the bowl back on and it all worked fine, fired up 2nd kick! I'm still stuggling to understand the dislike of Amal carbs!
I haven't sorted the plastics out yet but intend to in the near future, but am moving shortly and need a functioning bike. I've also had more than enough for a while of working on the bike in an unheated gargae in this weather!
Thanks for all the help you have all given me, I would have found it more confusing and fustrating without it.
Will
Will
Users browsing this forum: No registered users and 220 guests
