MT 500 Scrambler
Re: MT 500 Scrambler
Minter, Do you think it would be a good idea to fit a 16t front sprocket? or will the healthier engine give me enough grunt?
Previously I've had a couple of occasions when it felt a little too high geared on a some low speed short steep hills.
2024 (2012) CCM MT230
2002 BMW F650GS
2002 BMW F650GS
I run a 15 on my 500.. You can choose.. I just replaced what was on which was worn out..
Let me know what you'd prefer and ill fit it..
My intention will be for a bias more towards green laning rather than road or motocross. I think you're better qualified to decide which size would be best suited for my needs. Imagine you was taking this bike to do the twinshock trailfinder and then fit whichever you think is best.
Thanks.
(Tomorrow when I get time, I'm going to try and post some pictures to show my progress with the frame).
Thanks.
2002 BMW F650GS
2002 BMW F650GS
thanks for this thread Bonnielad, im finding it most interesting, please do put some piccies up if you can all the best wishes for the build.
I think Throb meant if using the bike on the road a 16t is better. A 14 tooth is better for low speeds steep hills and tracks. 15t is standard, 16 t is great on my 350 on the road.Throb wrote:If you're using it off road, a 16t will be nicer.
Ta,
- ZIP TIE
17 is standard on the 500 though and to be honest it pulls it pretty well as it has the gruntappyarry wrote:I think Throb meant if using the bike on the road a 16t is better. A 14 tooth is better for low speeds steep hills and tracks. 15t is standard, 16 t is great on my 350 on the road.Throb wrote:If you're using it off road, a 16t will be nicer.
Ta,
Its a 500 arry so gearing it down to. 16t should help off road with out compromising top speed too much on road..
Ill put a 16 on for you Steve..
16T sprocket fitted, cylinder fitted and head pulled apart..
Cylinder honed out too
Piston polished.. Rings are well within tolerence so theres a bit of a saving Steve!
Piston ring compression tool in action..
Cylinder on.. Cables tidyed..
Head now in bits, bearing worn out, seal not seated correctly, probably explains all the oil on the timing belt, valves letting by, Valve stem oil seals like bakerlite!
Here we go, my first attempt at posting photos (fortunately I found the tutorial).
I've stripped the paint off the front forks and then polished the ally. I can't make them perfect because of all the scars from its earlier life.
2002 BMW F650GS
2002 BMW F650GS
Users browsing this forum: No registered users and 13 guests
