Fuel injected Armstrong 500? Am I mad?
Blitz
Re: Fuel injected Armstrong 500? Am I mad?
Post by Blitz » Sun Jan 12, 2014 5:38 pm
Have you got an internal fuel pump fitted now?
Are you happy with all the parts or have you got bits in mind/upgrades.
I asume once you are happy with the EFI settings these can then be used on any 500 with your retro fitted parts ?
Yoof
Post by Yoof » Sun Jan 12, 2014 5:45 pm
The fuel pump is external and is fitted under the tank.
Its large and noisy and made in china... I have on off a Yamaha R1 that I may fit later but this one it working for now.
My fuel map would be a perfect starting point for another rotax 500 however its just like a carb and it effected by different inlet tracts and exhausts etc.
Blitz
Post by Blitz » Sun Jan 12, 2014 5:59 pm
So what's it like now from cold? Kick it. It fires up and runs? Reducing revs as it warms up and doesn't stall even if you throttle her ?
Ie everything the carb version won't do ?
Yoof
Post by Yoof » Sun Jan 12, 2014 6:14 pm
Starts well, when its cold I need to have a small amount of throttle open as I dont have a fast idle valve. After the "afterstart enrichment" turns off (about 150-400 engine cycles depending on engine temp) it settles down to a steady idle.
The fine tuning I need to do now is making sure it will start well at any engine temp, when thats done it should kick start ok and start on the button after a couple of cranks like a factory fuel injected bike. Also need to adjust acceleration enrichments and low speed responsiveness.
Blitz
Post by Blitz » Sun Jan 12, 2014 6:25 pm
Sound like your getting there. Impressive.
I know some people like the battle of a single carb bike but if I can change the bike to my liking then I will ride it more, so it's a win win for me.
My MT is my only bike so it's not a play thing.
Post by appyarry » Sun Jan 12, 2014 7:05 pm
I'm JEALOUS, and that's partly because you can buy Timothy Taylors in a local boozer any time you feel like it :-) And also because I love the work you've done. Well done, great example of what can be done with a bit of determination.
Thank You for sharing it.
Post by ellrider » Sun Jan 12, 2014 7:12 pm
appyarry wrote:I'm JEALOUS, and that's partly because you can buy Timothy Taylors in a local boozer any time you feel like it
as long as he has ID. :D
Yoof
Post by Yoof » Wed Jan 15, 2014 9:19 pm
Problem...
I have a voltage readout on my Acewell speedo and with the headlight on (55w H4) it is showing 12.0V :? (need to veryify the accuracy of this ...
So I think my inline fuel pump is drawing alot of power.
Going to have a go with a Yamaha R1 pump that Ady got me and see how that goes. But im thinking of retrofitting a f650 alternator which is 400W... watch this space.
Post by ellrider » Thu Jan 16, 2014 6:46 am
Go for it Yoof,
When you going to fit a water cooled engine, at this rate you will end up with a F650.
Post by twmtomos1 » Thu Jan 16, 2014 9:27 am
ellrider wrote:Go for it Yoof,
why dont you buy a F650 and paint it green you can still come to the club meetings to fix all the MT :lol:
Users browsing this forum: No registered users and 40 guests
