Bunkers MTatty 350 into MTourer 604
Re: Bunkers MTatty 350 into MTourer 604
Post by Bunker » Sat Feb 13, 2010 11:11 pm
OK, the long awaited pictures of where Im at as of today:
MTatty's old lump
New 604 lump - this will be dressed in MTatty's old outer casings and the whole thing will go black.
A thing of beauty. All green is genuine NATO IR non reflective, for what its worth!
Main components
Main components (see Diggers' stone guard)
Pannier box frame components
Shock springs and seat mounts
Chosen to refurb old ones as new ones too short
This will get a cover made of an old Bergen.
Box of NEW components gathered over the while, switch gear, coil, reg/rect, brake calipers, side panels, etc etc
I chose to rebuild the old wheels as I want stainless spokes. Rims have been powder coated too, its a satin black, looks fantastic.
Apophis
Post by Apophis » Sat Feb 13, 2010 11:19 pm
Oh ye
now that looks the mutts so far I like that green Darker than mine
but that may be the screen im looking at it on
now its just putting it back together :lol: :lol:
Harleyphernalia
Post by Harleyphernalia » Sat Feb 13, 2010 11:33 pm
Damn your putting me to shame again!! :mrgreen:
i need to get a breeding pair, then maybee i can get some time to tidy mine.
looks good so far , how much hs it cost you to get the frqame and parts blasted and coated???
just interested, as the long term results are gonna be much better i guess, as mines getting very tatty again, :oops: and i feel needs some long term love and attention.
feel free to PM the cost rather than post where her in doors can berrate you with the 'how much!!?' stick... :lol: :lol: :lol:
Post by Bunker » Sun Feb 14, 2010 12:42 am
how much hs it cost you to get the frame and parts blasted and coated???
was Ă‚ÂŁ200 cash. I think Apophis' was roughly the same. Im disappointed with some of it as he has painted the bearing surfaces and poorly masked the oil filler neck. The fork sliders are full of oily sand too. He was supposed to mask it all off properly hey-ho. Im going to thoroughly rinse out the oil tank - was thinking of using 2l of white spirit and a thorough sloshing, pouring through an oil filter and repeating a few times, that way it should clean any old muck out - any better thoughts?
I need now to get:
604 gasket to put the barrel back on with,
Sleeved spacers for swing arm/ engine fit (MT engines sit on a 14m swing arm spindle rather than the 16mm CCM, so the MT lump comes with the casing holes sleeved down to 14mm).
Needle bearings for swinger
Short cabled remote choke lever
K&N air filter
Battery
Loom (will make one)
Seat (to be made)
Rear Tyre (Distenza)
Stainless spokes
Braided brake lines (Apophis sorting)
Modify rear end to add rear pannier box
New chain guard
Roy W
Post by Roy W » Sun Feb 14, 2010 9:37 am
Simon
Are those green parts powder coated or painted?
Roy
Apophis
Post by Apophis » Sun Feb 14, 2010 9:45 am
that's the only thing with the process
my fork sliders where the same i put the jet wash in the top and just held it in place for 10 mins until it had all been washed out the bottom.
the powder coaters had washed out my tank and it was fairly clean bit i used a drill pump with a filter in line before it went into the oil return then had a pipe from the oil supply union (lowest point) to the bucket i did it this way to monitor the Crap coming out and did this until there was no crud coming out
the rig i used is with Digger and Green machine at the moment
a dremal is fantastic for cleaning up where there should be no powder coat
Post by TDIPower » Sun Feb 14, 2010 11:22 am
Good job i posted about them being on offer the other day then.
sidecarwillie
Post by sidecarwillie » Sun Feb 14, 2010 11:45 am
powder coating is a very good insulater so make sure your earths are ok. i found out the hard way a few years ago when my freshly done up nimbus stopped in wales,but of course it could have been the bad air in that foreign country!!!!!!!.
frenchy3
Post by frenchy3 » Sun Feb 14, 2010 4:02 pm
I agree with the last comment. I had my CCM604 frame powder coated and could not get any electrical circuit to work and would not turn over. It turned out the powder coating was that good the battery cable connected to the subframe would not earth and there was no earth between the subframe and main frame either. It galled me to have to start scraping away the new finish.
Steve.
Post by Bunker » Sun Feb 14, 2010 5:37 pm
Its powder coated Roy and yes, sadly I intend to dremel the earth points off :cry:
Users browsing this forum: No registered users and 212 guests
