Iceland 2014 - Planning & Preparation
Moderator: Event Co-ordinator
Daj
Re: Iceland 2014 - Planning & Preparation
Post by Daj » Mon Jul 28, 2014 12:15 pm
Respect the trolls and hidden folk. http://en.m.wikipedia.org/wiki/Hulduf%C3%B3lk
Daj
Sent from my KFTT using Tapatalk
MT500e
Post by bth2bth2 » Mon Jul 28, 2014 4:02 pm
ellrider wrote:If you are travelling alone don't go too far off the beaten track.
i believe its not hard to be off the beaten track over there.
namtip
Post by namtip » Mon Jul 28, 2014 8:15 pm
Joth - what a brilliant blog! I might be PM'ing you over the next few weeks asking questions.
I will be riveting a new chain methinks - then I don't have to worry about spare links/clips. As for coil, CDi, and rectifier, I will be installing new ones and taking the old ones as spares providing I have room.
Thanks for all the responses so far - I really appreciate it.
And yes, I really don't want to go upsetting the trolls/hidden folk...!
Joth.Hill
Post by Joth.Hill » Mon Jul 28, 2014 8:52 pm
No problem, I will help where I can.
Joth
Post by hounddog » Mon Jul 28, 2014 10:17 pm
Sounds like a fantastic trip. Here's a few tips I've picked up from overseas bike travel
admin - get a EHIC card ( free from nhs ) , important even if you have medical insurance .
Leave a trusted friend /relative in UK with copies of your passport, bike papers, insurance details , bank card emergency numbers etc, and website and phone numbers of MT parts suppliers just in case a part needs to be bought and couriered out to you .
Carry a spare set of bike & lock keys, and spare specs if you wear them
If a MT500 falls off its stand or you drop it, the bits that most likely tend to break are the front brake or clutch lever (unless you have bark busters of course)- I rode a MT500 about 100 miles with half a front brake lever once which was quite entertaining ! - Not a totally silly idea to carry spares
Worth carrying a lightweight foot pump or 12v inflater, much easier than a bicycle pump
Pair of good inner tubes and a puncture kit with fresh rubber solution glue,(old stuff goes solid with age ) , decent quality tyre levers
Usual spares and tools per FAQ 2.8
Check your brake shoes to ensure enough lining left for the trip.
At night if parked outside , a bin bag over each end of handlebar will keep the rain out of the switches
And most importantly , enjoy :D
Post by Bunker » Tue Jul 29, 2014 10:05 pm
Practice changing the clutch cable and timing belt. Oil your cables. Check your nuts n bolts are tight.
namtip
Post by namtip » Wed Jul 30, 2014 8:03 pm
Bunker wrote:Practice changing the clutch cable and timing belt. Oil your cables. Check your nuts n bolts are tight.
I've practiced both, and the cables will be getting a good oiling. I checked nuts and bolts a couple weeks ago and to my shock some of the major ones were loose :shock: . Not rattly loose, but no real effort on a spanner to turn them either.
HoundDog wrote:Worth carrying a lightweight foot pump or 12v inflater, much easier than a bicycle pump
Pair of good inner tubes and a puncture kit with fresh rubber solution glue,(old stuff goes solid with age ) , decent quality tyre levers ... And most importantly , enjoy :D
All good tips Ian and duly noted - thanks. I have two fresh puncture kits, a hand pump (with CO2 option) and two quality tyre levers in the post. Barkbusters are fitted so no worries about the levers breaking in a fall. EHIC card - hadn't thought of that - good call.
Post by hounddog » Fri Aug 22, 2014 1:49 pm
and keep away from active volcanoes :o
http://www.bbc.co.uk/news/world-europe-28870969" onclick="window.open(this.href);return false;
BIGYAM
Post by BIGYAM » Sat Aug 23, 2014 9:23 pm
Cambelt, and i would take spare cam and crank seals for sake of about Ă‚ÂŁ8 =pullers for the pulleys, spark plugs/tubes etc
Post by twmtomos1 » Sun Aug 24, 2014 7:33 am
id carry a couple of cam belts ,and locktight had the top pulley come loose,also it would be worth taking Minter with you problems solved 8-)
Users browsing this forum: No registered users and 179 guests
