I did ask that question! But only if i had 50 sets made!freddy54 wrote:Minter wrote:Wish i could say it was my handy work George! But it was a local exhaust place that made em! - eventually!P.I.STAKER wrote:very nice gary.
you have made a very good job of those.
regards
george
can they make s/steel ft and middle pipes up for an mt350 cheaper than the major supplier?
Full Flow Stainless Exhaust Link Pipe
Re: Full Flow Stainless Exhaust Link Pipe
well is there 48 others?
what was the best price you got for 3 std but stainless pipes?
£280 then the VAT, cheaper to go to Force, he has plenty, my primary aim is to build the motors and supply performance enhancing mods/advice..freddy54 wrote:well is there 48 others?
Pipes all posted first class signed for at 0900 this morning..
Evening all...
Does anyone else want a link pipe? I shall be putting in another order soon if folk are interested?
- Contact:
Hi Gary
Yes please. 1 for me as we'll they look great
could they do one with the rear section swaged out to 50mm OD ?
I'm sure they could Roy.. Like the bit that connects to the centre pipe.. That has been 'flared' so that it goes over the centre section.. Is your slip on of a larger diameter?Roy W wrote:Gary
That's correct, the Supertrapp and the White Bros. end cans have a 50mm slip on section.Minter wrote:I'm sure they could Roy.. Like the bit that connects to the centre pipe.. That has been 'flared' so that it goes over the centre section.. Is your slip on of a larger diameter?Roy W wrote:Gary
If you return it Roy i'll have the end flared to your requirements, Just let me know what diameters you'd like id od etc..Roy W wrote:That's correct, the Supertrapp and the White Bros. end cans have a 50mm slip on section.Minter wrote:I'm sure they could Roy.. Like the bit that connects to the centre pipe.. That has been 'flared' so that it goes over the centre section.. Is your slip on of a larger diameter?Roy W wrote:Gary
