strip and rebuild
Drifter
Re: strip and rebuild
Post by Drifter » Sun Apr 21, 2013 5:59 pm
Pink is about 3 to 4 seasons ago keep up with the trends:cool::cool::lol:
Sent from my GT-P3110 using Tapatalk HD
MT350e
Ride safe / Ride MT
freddy54
Post by freddy54 » Sun Apr 21, 2013 6:00 pm
monochrome , must be a 60s bike!
Homer
Post by Homer » Sun Apr 28, 2013 9:27 pm
HELP
Tried to re assemble the throttle, I just can't seem to get the cables right, they are both pulling but against each other ! Can anyone explain in VERY simple terms how the cables route at the twist grip ?
Also connected up the brand new wiring harness, I have no power to anything :evil: but the starter motor, any ideas ?
Post by Wirralman » Sun Apr 28, 2013 9:38 pm
Connect the cable to open the throttle first, once you have that sorted the other one just drops in. Sounds vague, but it works for me
Eric
Post by ZIP TIE » Sun Apr 28, 2013 10:02 pm
Homer wrote: Also connected up the brand new wiring harness, I have no power to anything :evil: but the starter motor, any ideas ?
Blackout switch
Homer
Post by Homer » Thu May 02, 2013 4:05 pm
Thanks for the replys,
i now have power :oops:
Try as i might to bleed the rear brake, its just not having any of it, i'm thinking the resevoir ( its been moved next to the master cylinder by the previous owner ) is too low to work correctly.
Could someone tell me the measurement of the centre stand from the pivot point to the foot.
Thanks
Mark
Roy W
Post by Roy W » Thu May 02, 2013 4:17 pm
Homer wrote:Thanks for the replys,
Thanks
Mark
Also try some ptfe tape around the bleed nipple thread, commonly they will suck air back in around the threads as you release the pedal whilst bleeding. I had a similar problem and the tape solved it.
Thumper
Post by Thumper » Thu May 02, 2013 4:18 pm
Or replace the stupid ball bearing nipple with a proper one
Post by ZIP TIE » Thu May 02, 2013 4:43 pm
Thumper wrote:Or replace the stupid ball bearing nipple with a proper one
^^^ what he said!
Post by Wirralman » Thu May 02, 2013 6:03 pm
It took me about three days the first time I did it, disconnecting the pipe, raising the caliper etc etc. It was MOST frustrating.
The best tip for me was to unscrew the bleed nipple and remove ball bearing. Then use a syringe to fill the caliper up.
Then I just pump fluid through until no bubbles show at which point I start bleeding the brakes in the conventional way.
I assume you've cleaned the ball bearing seat and have a new 7/32" (from memory) ball bearing from your local cycle shop. The old one will have rusted on the top exposed side and may not easily re-seal. Or you can fit a different nipple.
Users browsing this forum: No registered users and 27 guests
