just a little reminder this coming weekend it show time at Sheppton malett.
its a good show i should be there with the MT on the HDRCGB stand as last two years.
say hello if you are coming ,(got to get the bike fixed first as it broke on the way to the Dragon, a club member sent me the parts so just got to drop the engine out and fix the problem.)
john
BRISTOL classic bike show 19th-20 feb
Moderator: Event Co-ordinator
Re: BRISTOL classic bike show 19th-20 feb
If its just the cam and top pulley then there is no need to remove your engine, just take the cam belt cover off.
changing the head Franc the reason the cam wheel came loose was the bolt holding it had broke as i have now got a spair head i am going to swapFranc wrote:If its just the cam and top pulley then there is no need to remove your engine, just take the cam belt cover off.
and sort out the problem later.
should get it sorted tomorrow with some luck
john
You can remove the cam with the engine in the frame it's quite a quick job and a lot easier than dropping the engine and removing the head.
HTH
It might be a little more difficult with the bolt snapped of in it but probably easy enough to work around.
HTH
Users browsing this forum: No registered users and 155 guests
