Best way I found so far is with a bandsaw, the jigsaw blades heat up, melt the ally filings and clog up, the bandsaw blade is so long it doesn't retain as much heat.nickp500 wrote:The angle grinder worked ok with a very thin stainless steel cutting blade in. Was going to use a jigsaw but thought it would be too vicious and would leave a rough edge.truslack wrote:They look brilliant, well done. A tip for cutting ally chequer plate in future is use a jigsaw not an angle grinder!
Nick
Better still use a guillotine if you can find one.
