Project Armstrong MT604 Supermoto/MXer/Traily
Re: Project Armstrong MT604 Supermoto/MXer/Traily
Cheers Simon its going to have a drum rear end - The super moto wheel will be laced onto a 500 hub..
With a special anti corroding spoke ring on the hub?Minter wrote:Cheers Simon its going to have a drum rear end - The super moto wheel will be laced onto a 500 hub..
Or is that still in the pipeline? (wedged in the pipeline...)
Nick
MT560e
BMW R75/5
Honda CB250rs
MZ TS250
BSA M20
BMW R75/5
Honda CB250rs
MZ TS250
BSA M20
Yep with a special anti corroding spoke ring! Its now with Apophis's metal guru, so hopefully be available soon!nickp500 wrote:With a special anti corroding spoke ring on the hub?Minter wrote:Cheers Simon its going to have a drum rear end - The super moto wheel will be laced onto a 500 hub..
Nick
Today has been one of those days! Airbox and battery box been on and off a dozen times! Ive now had to use the 350 airbox so that it all fits nice with the battery box also off a 350 and the inner mudgaurd again off a 350. The circuit breakers will mount on top of the air box and fit nice below the 350 seat..
Its now starting to look like a bike again.....
Tomorrow, i'll be trying to sort out the electrics!
- StackerMel
- Contact:
You are better off getting rid of the airbox altogether, the filter will be too restrictive for the 604. as for the circuit breaker, with the fuse box out the way this can be mounted on the rear inner mudguard bit.
Just thoughts you may have better plans
Mel
Mel
HD MT604e-Kochanski
HD MT350- Kryten- rough and ready
MT500 - Cat
MT500 - Lister
Can-Am Bombardier 250
MT500 - Cat
MT500 - Lister
Looking good!
That exhaust looks a bit tasty, whats it from?
MT560e
BMW R75/5
Honda CB250rs
MZ TS250
BSA M20
BMW R75/5
Honda CB250rs
MZ TS250
BSA M20
Hi Mel, I have got a cone filter that came with the engine and carb, but ideally the air box is what i want - especially for wet wales or dusty spain! Ive got a k and n panel filter which i intend to use and I may open up some of the airbox cover... I'll find out when it runs!StackerMel wrote:You are better off getting rid of the airbox altogether, the filter will be too restrictive for the 604. as for the circuit breaker, with the fuse box out the way this can be mounted on the rear inner mudguard bit.
Mel
Hi Nick, Its a bespoke 604 exhaust built by apophis's metal guru! hopefully the spoke rings will look good too!nickp500 wrote:Looking good!
tried the 604 motor on the Airbox but the Dyno guy could not get enough air into the engine
so you may wish to rethink that before you get to far Gary
Oh dear - cheers for the heads up, glad i'm doing a rough build first to iron out all these little dramas!Apophis wrote:tried the 604 motor on the Airbox but the Dyno guy could not get enough air into the engine
Users browsing this forum: No registered users and 53 guests
