Oct 1st 2011 MCC Edinburgh Trial
Moderator: Event Co-ordinator
green_machine
Re: Oct 1st 2011 MCC Edinburgh Trial
Post by green_machine » Mon Oct 03, 2011 4:55 pm
Spannerhands and your mate Matt,
Well done on Saturday. Was good to see you both breeze up Bamford Clough with not a care in the world... ;) . Shame you couldn't stop for a chat!
I did pray you didn't stall it and have to do a kickstart on an incline with an audience.
Rear shocks looked interesting. Were they the same length as the original Ohlins?
Stuart
DSG
Post by DSG » Tue Oct 04, 2011 11:21 am
Seen at the breakfast stop:
Dave
Spanner hands
Post by Spanner hands » Tue Oct 04, 2011 11:32 am
Dear Stuart
Yes the shocks are the same length as standard for the 500. The 350 has longer shocks as standard.
They came second hand with another MT I bought. They are very expensive new I think around Ă‚ÂŁ400.
The great advantage is that you can change the spring rate just by changing the air pressure although this does require a special pump which is another Ă‚ÂŁ60.
They work realy well as long as you fit them with the schrader valve forward. I fitted them the wrong way around first time and sheared of the valve on one of them. I finished the 2010 Exeter with 2 inches of suspension travel looking like Dennis Hopper in Easy Rider :cry:
If you need any information on the part number of shock I can probably find it.
All the best David
Users browsing this forum: No registered users and 218 guests
