Alps or bust
Moderator: Event Co-ordinator
Re: Alps or bust
Have you checked to make sure you haven't got a stiff link in the drive chain or lots of slack making it jump at lower revs?
Re: Alps or bust
Chain tension is fine. Chain is good. Only happens occasionally & don't want to provoke. Cheers
MT500
Triumph TT600
BSA B40 Trials
Kawasaki Z200
Velosolex 1700
Honda P50 and PA50
Triumph TT600
BSA B40 Trials
Kawasaki Z200
Velosolex 1700
Honda P50 and PA50
Re: Alps or bust
What about the nut on the drive sprocket has it worked loose? or the cap heads on the rear.
Re: Alps or bust
Just tried its fine but there is backlash of about a knobble on the tyre, not sure what is normal.
MT500
Triumph TT600
BSA B40 Trials
Kawasaki Z200
Velosolex 1700
Honda P50 and PA50
Triumph TT600
BSA B40 Trials
Kawasaki Z200
Velosolex 1700
Honda P50 and PA50
Re: Alps or bust
Ie I can rock the rear wheel about 5 deg before it stops, but I think that's normal ?
MT500
Triumph TT600
BSA B40 Trials
Kawasaki Z200
Velosolex 1700
Honda P50 and PA50
Triumph TT600
BSA B40 Trials
Kawasaki Z200
Velosolex 1700
Honda P50 and PA50
Re: Alps or bust
Just checked mine and in first gear I get an inch to an inch and a half at the circumference of the tyre.bigfatcat wrote:Just tried its fine but there is backlash of about a knobble on the tyre, not sure what is normal.
Re: Alps or bust
No ruler but looks about 2 inches in mine
MT500
Triumph TT600
BSA B40 Trials
Kawasaki Z200
Velosolex 1700
Honda P50 and PA50
Triumph TT600
BSA B40 Trials
Kawasaki Z200
Velosolex 1700
Honda P50 and PA50
Re: Alps or bust
Too dark now.Will look again tomorrow, but it feels backlashy. I'm fine if it doesn't get worse, but they seldomfix themselves. Suspect it will go from occasional to slightly more than occasional. Thanks for the help
MT500
Triumph TT600
BSA B40 Trials
Kawasaki Z200
Velosolex 1700
Honda P50 and PA50
Triumph TT600
BSA B40 Trials
Kawasaki Z200
Velosolex 1700
Honda P50 and PA50
Re: Alps or bust
rebooted phone & images now working
MT500
Triumph TT600
BSA B40 Trials
Kawasaki Z200
Velosolex 1700
Honda P50 and PA50
Triumph TT600
BSA B40 Trials
Kawasaki Z200
Velosolex 1700
Honda P50 and PA50
Re: Alps or bust
Luzern in Switzerland. Absolutely roasting weather. Won't take long to run out of money here though.
MT500
Triumph TT600
BSA B40 Trials
Kawasaki Z200
Velosolex 1700
Honda P50 and PA50
Triumph TT600
BSA B40 Trials
Kawasaki Z200
Velosolex 1700
Honda P50 and PA50
Users browsing this forum: No registered users and 5 guests
