it started so small
ASHCROFT
Re: it started so small
Post by ASHCROFT » Sun Apr 18, 2010 3:24 pm
well it's coming together nicely
oil filter changed
gaskets left, right and underneather changed
front caliper stripped and new pistons seal etc. suprised how easy this was now got the pain of bleeding!!!!!!
new braided hoses on front and rear with new pads all round so got to bleed the rear as well arghhh
new wheels and tyres too shiney : :lol:
new cush drive but i was suprised to find no bolt retainers on the rear cush drive (the ones you fold over to stop nuts coming out) so it appears be riding withone since bought so will be ok for a while until i get some
exhaust back on
so just got to do before stafford
new m14 wahser for rear wheel lost in my s**t whole of a garage somewhere
bleed all lines
timing belt
put some oil in
new spark plug
tank back on
pannier mouts back on
pray it starts
and if really lucky with time rear mounts on but not looking good
Post by TDIPower » Sun Apr 18, 2010 7:57 pm
good work!!! I must do some bits on the 350 for Friday. Need to get my arse into gear. Still need to get the bathroom finished, some reports done then I can get on.
ASHCROFT
Post by ASHCROFT » Sun Apr 18, 2010 8:21 pm
well 9 pm and just sat down
it starts wipee!!
but still left
new cush drive but i was suprised to find no bolt retainers on the rear cush drive (the ones you fold over to stop nuts coming out) so it appears be riding withone since bought so will be ok for a while until i get some but will try before stafford
m14 rear wheel washer ill get tomorrow
bleed all lines, rears been a bi**H
put new chains and front sprocket on, and short out clutch cable
happy evenings coming along
:D :D
Post by Wirralman » Sun Apr 18, 2010 8:41 pm
I'd start with bleeding the front brake. That way you will have more time to put pressure on the system , tie back the lever and leave it overnight. That can be sorting itself out whilst you do other jobs
Good luck Eric
ASHCROFT
Post by ASHCROFT » Sun Apr 18, 2010 9:06 pm
thanks, been and done
mtt.tr
Post by mtt.tr » Sun Apr 18, 2010 9:31 pm
Wirralman wrote:, tie back the lever and leave it overnight.
Good luck Eric
Why does this work i have no idea but improved my bike
Post by TDIPower » Sun Apr 18, 2010 10:07 pm
my thoughts on this are that the bleed nipple system on the bike is not like most. A 'normal' nipple is pointed with a hole off set to one side that then runs up the inside so when you crack it off the fluid/air has a free/direct path out. The brembo units have a ball bearing in the hole then the nipple doesnt have the point, its just like a bolt with a hole through the centre so the ball seals the caliper by being pressed into the hole by the nipple which inturn is sealed by the ball stopping water gettng into the inside of the threads. This is good as you dont get the issues the same with nipples rusting from the inside out into the caliper BUT when you crack off the nipple and pump the fluid the ball bearing pushes up against the base of the nipple sealing it off. So with the lever pulled back and the nipple open you basicly have a pipe with open ends and gravity becomes your friend.
Ive tried traditional, pressure and vacuum bleeding systems on MT brakes and have to say the traditional combined with the clamp open the master is the most effective.
ASHCROFT
Post by ASHCROFT » Sun Apr 18, 2010 10:40 pm
might sound like a silly question, when you tie the lever back and open the bleed nipple do you leave the top on the cylinder to stop all the fluid going through
Roy W
Post by Roy W » Mon Apr 19, 2010 6:45 am
ASHCROFT wrote:might sound like a silly question, when you tie the lever back and open the bleed nipple do you leave the top on the cylinder to stop all the fluid going through
Yes you can leave the cylinder lid on. The microscopic air bubbles just return to the cylinder and are replaced by fluid. You may have to top up afterwards depending how much air comes out.
Roy
ASHCROFT
Post by ASHCROFT » Mon Apr 19, 2010 10:38 am
so thats the front one done, although the pistons are not pulling back in enough once applied
i did the full strip and new seals and pistons so will see if it settles down
on to the back one now
Users browsing this forum: No registered users and 58 guests
