Project Girt.
Franc
Re: Project Girt.
Post by Franc » Thu Dec 10, 2009 5:18 pm
You got me :oops: :oops: :oops:
nick
Re: Project Girt.
Post by nick » Thu Dec 10, 2009 6:33 pm
Great news to hear you've got it sorted :D
Nick
Armstrong CV500e (1985)
Honda CB750 four (1974)
Yamaha DT 250 (1972)
Franc
Re: Project Girt.
Post by Franc » Fri Jan 15, 2010 3:21 pm
Just a quick update, FUBAR went for his first MOT today, and failed, :(
They didn't like the Perrelli rallycross front tyre, it has no BS or equivelent stamp on the side walls, they also got me on no split pin in the rear axle, and lack of braking power on the rear.
I have done the first two, and bled the brakes 5 times over, even taking the caliper off and shakinhg it to release the trapped air, new brake pads, steel braided hoses, the whole nine yards!!
Still can't get the rear brake to work properly, only thing I can think off is the non-standard rear master cylinder is not man enough for the job, does anyone have a spare??
Re: Project Girt.
Post by TDIPower » Fri Jan 15, 2010 4:32 pm
there was a brand new one for Ă‚ÂŁ60 on the mod spares site someone posted a link to the other day. sorry cant remember more than that.
Re: Project Girt.
Post by Wirralman » Fri Jan 15, 2010 5:52 pm
Ex KL motorsport 9 months ago
84732395 Rear brake mstr cyl assy qty 1 Ă‚ÂŁ36.10ea
Plus Vat and postage
twowheel
Re: Project Girt.
Post by twowheel » Fri Jan 15, 2010 9:52 pm
Are you sure the calliper is working ok and that the pads are bedded in? I thought I had a problem with my transalp rear brake, which at 2,000 miles and after bleeding and knowing there was no air in it I just put down to being a crap brake, but then I did wonder if it was bedded in right and so going down a local mountain side I gave it some SERIOUS USE! and bingo half a mile down there it bit, problem cured.
I also remember having a hell of a problem getting all the air out of my old BM back brake system.
Chris
Franc
Re: Project Girt.
Post by Franc » Fri Jan 15, 2010 10:03 pm
Pads are brand new, so bedding in could be the problem, but the resistance of the rear brake is not even man enough to hold it still on the road outside my house. surely this should not be the case.
Rang steve at KL this afternoon, funds dictate that the retest may have to wait a while.. :(
twowheel
Re: Project Girt.
Post by twowheel » Fri Jan 15, 2010 10:20 pm
Could STILL be the case that the pads won't grip the disc, I would think that any master cylinder KNOWN to be in good order combined with a fully working calliper to disc would perform better than that. One thing you could try is chalk the disk all over squeeze the brake on and roll the bike it will show you the contact area, but this is only a guide and won't tell you everything.
Chris
Re: Project Girt.
Post by TDIPower » Fri Jan 15, 2010 11:30 pm
my mistake I thought you wanted a caliper not master... Did you fit normal or sintered pads?? if you have an angle grinder and a worn flappy sanding disk take your disk off and give it a light wiz over (unless you have a new disk fitted). take it for a run use the rear with light but frequent pressure.
Green Goblin
Re: Project Girt.
Post by Green Goblin » Sat Jan 16, 2010 6:14 am
I agree with the above comments take the bike out and give the brake some use, it will probably get better.
Stewart
Users browsing this forum: No registered users and 206 guests
