Nut and Bolt Rebuild on Emma
Re: Nut and Bolt Rebuild on Emma
Brilliant job. But aren't you worried about the shiny nuts and bolts giving your position away when they glint in the moonlight
cracking rebuild gromit
Thanks for the comments Guys
had her running today and it just needs to be set up on the Dyno
here is the last clip of the DVD I have uploaded to You Tube
http://www.youtube.com/watch?v=tfKJq_e0Y2w
Nice one mate, good to see it running
Well done craig
Great work fella
Daj
Great work fella
Daj
MT500e
MT500e
when are you getting it dyno,d craig and is your engine the 600 or 644,
its all done now
mine is a 604
carb all set up i jumped on it and was pulling 110 and it was still climbing
we did 3-4 power runs
ended up with 39bhp
but the torque was around the 68 mark
mine is a 604
ended up with 39bhp
cheers craig, did you leave the k+n on it, also is the x over pipe bigger dia than the std one, i know the headers are that you had made up, and did you leave the 17 tooth sprocket on, what cam did you use,
Mart off hand I recal having the headers drop into a 44 or 45mm od right through to the rear Can so the CCM can could be sliped on I replicated the CCM and the MT exhausts as much as i could CCM boars MT sections with the final section be able to mount on the OEM MT centre section
and on the new centre section
hope this helps
what are you up to then you little tinker come on let on
hope this helps
nothing, honest, i was just curious as to how you finally got everything sorted,
Users browsing this forum: No registered users and 65 guests
