last week fitted new clutch plates and a sportax dellorto carb kit and after a week riding its a new bike,first kick starting,tickover on and off choke,better mpg and more pull,a big step up from the mikuni I was running and can recommend the carb,great kit.fitted a gps speedo today as fed up of snapped cables,great piece of kit looks stock and has a neat direction display.
You'll have a full fairing next. It's been done before when trialled by the policedeadgrass. wrote: ↑Sun Nov 04, 2018 4:30 pmfitted new front to my touring armstrong, also bigger tank, heated
Took me ages to realise that picture is of the inside of your muff .I wondered what is was
yes mick,
i've worked out this year if i dont bolt them through the end of the bars i can leave the barkbusters on and it helps keep the material off my fingers.
ohh dear,[why do i feel the need to faff]
it seems after a few road trials i've created a monster,
ok up the the near legal limit shall we say ,try to push beyond and its starts to weave like a ,
shut the throttle no help,
lean over the front no help,
just ease off the power and hope is the only way,
checked tyre pressures,head bearings,
removed big front mudguard no difference,
raised forks through yokes no difference,
took screen off,try tomorrow,
Too much time on your hands, get a mistress.
It does look tall.
Did flat face have the same problem Dave?deadgrass. wrote: ↑Mon Nov 05, 2018 8:45 pmohh dear,[why do i feel the need to faff]
no gary [and these are the same forks]Minter wrote: ↑Tue Nov 06, 2018 7:53 amDid flat face have the same problem Dave?deadgrass. wrote: ↑Mon Nov 05, 2018 8:45 pmohh dear,[why do i feel the need to faff]
just a small amount of movement from that bike at higher speed easily compensated for,
this is different i cant control it,
im guessing putting all that wind resistance [load] on the forks big screen ans big muffs is the cause,
i will keep altering it till it stops,
yours is fixed to the frame not to the moving parts of the steering,
i may have to make something similar but smaller again,
I can't,
Our lass won't let me.
Users browsing this forum: No registered users and 21 guests
