Nut and Bolt Rebuild on Emma
ambassador
Re: Nut and Bolt Rebuild on Emma
Post by ambassador » Wed Sep 16, 2009 7:46 pm
:lol: :lol:
Apophis
Post by Apophis » Fri Oct 23, 2009 9:14 pm
Post by Bunker » Fri Oct 23, 2009 9:31 pm
looks triffic mate
Phatphil
Post by Phatphil » Sat Oct 24, 2009 9:45 am
How will it clear the rear tyre sidewall without the original flattened section ?
Apophis
Post by Apophis » Sat Oct 24, 2009 10:52 am
the rear can clears the side wall Via Straight edge it is about 10mm away and the exhaust was taken up out the way as well as you can see in the pic
it has all been measured to not be in the way at all
wife took this pic with her crapy phone so i thought i would also add it sorry for the quality
2009-10-23 20.16.56.jpg (56.32 KiB) Viewed 961 times
digger
Post by digger » Sat Oct 24, 2009 9:15 pm
Have you given him the nod to start mine yet Craig??.
MT 500 "Inky" (short for incontinent), not now Minter,s sorted it :D :D
1936 Bsa R4
1961 Triumph Trophy
1966 Norton N15CS
1971 Laverda SF
Post by TDIPower » Sat Oct 24, 2009 9:22 pm
noticed the pannier mount on the near side is back to front, you have the tie bar mount facing forward.
Apophis
Post by Apophis » Sun Oct 25, 2009 7:46 am
nice spot on that but it is only there for the Exhaust guy to make the exhaust up
I havnt done fitting the Frames in the DVD yet so it is all coming off again
if you look realy close you could also catch there is only 3 Fixings holding the front disk on as well
:lol: :lol:
Post by TDIPower » Sun Oct 25, 2009 11:36 am
the exhaust you have... can that be fitted with all the pannier stuff inplace, does it follow the old routes etc.
Im liking that and Might be interested down the line when the 350 unit bites the bullet
Apophis
Post by Apophis » Sun Oct 25, 2009 1:17 pm
it will indeed fit it has been done so that it is more or less the same as the original
so there are headers, center section then a riser section to slip a rear can of your choice on
I am also having it done so this can be made out of the same bore as the original 350
for headers and center section
the last section is going to also be made so it will slip onto the original mid section
for the 350 and the 500
Users browsing this forum: No registered users and 25 guests
