Its the same as the one on my blue trail bike version and it does sound good! There is a video of it going up Bamford Clough somewhere on here complete with sound track!jungleMTbiker wrote:mmmmmmmm, titanium. How does it sound? Have you had it running yet? It looks the goods.
Project MT500 Twinshock Motorcrosser
Re: Project MT500 Twinshock Motorcrosser
After many an hour trying and testing different cranks, pistons, cams, heads, clutches and exhausts, ive come up with the following....
I'd like to get it set up on a rolling road but time is running out for this weekends King of the Castle event at farleigh castle this weekend...
5 speed close ratio 'box..
Sportax clutch..!
Special Crank!
RHS with semi slipper high compression piston and 'special' bolts holding crank cases together!
Special clutch fitted - note no counter balance shaft..
Nice piston!
Yep! nice Piston!
604 head with 36mm inlet valves.. all polished and re ground
Special valve springs and caps and rockers..
Titanium even in the parts you wont even see!
Ran up on the test bed... wow its got some compression!
In the frame, at last..
Runs well, must be the 32mm headers! Hopefully if these work better than the 28's i'll get them produced..
Sportax clutch..!
Special Crank!
Nice piston!
Yep! nice Piston!
Mmmmmmm, nice.
What's the final displacement on this one? 640?
I've left the balance shafts out when rebuilding Honda XL/XR500 engines, can't say as I've ever actually missed them!
It's only 490 cc now..!
40cc can a 16 year old ride itMinter wrote:It's only 40 cc now..!
Moto Guzzi S3
Moto Guzzi Spada (pimped)
Defender 90 200TDI
Moto Guzzi S3
Defender 90 200TDI
thats predictive text for you! should read 490cc!!Andrew wrote:40cc can a 16 year old ride itMinter wrote:It's only 40 cc now..!
Minter wrote:Nice piston!
Wow there is a certain sexiness about this picture... if there were an MT-Porn section this could easily be the centrefold
Gotta stop drooling...
- arceye
That's just blown my mind man...
Let us know how you get on at Farleigh Castle. Take a video !
Users browsing this forum: No registered users and 65 guests
