Similar! Just a sh*t load lighter! No electrics and lots of titanium and ally..Roey wrote:It looks the same as your other one !
Did you see yours in front of it in an earlier picture!..
Yep, has a few scars and scratches on it now thoughMinter wrote:Similar! Just a sh*t load lighter! No electrics and lots of titanium and ally..Roey wrote:It looks the same as your other one !
Cheers George, using the original bash plate now just drilled with 2p size holes as it was lighter than the thick ally!P.I.STAKER wrote:how did you get on with the ally sump/bash plate, did you manage to make one gary?
i presume this was the one you required the ally spacers for.
looks excellent
Hi, the silencer is titanium I'm trying to make it as light as possible. Its designed for a ccm. It fits to the standard centre section with a sportax link pipe.. Its all very expensive but does save quite a bit of weight..jungleMTbiker wrote:I see you've moved away from the Force performance silencer--what is the new one? Is it something that was intended for another bike, and if so, how much adaptation was needed to make it fit where it is now?
Users browsing this forum: No registered users and 228 guests
