new project
deadgrass
new project
Post by deadgrass » Sat Mar 01, 2014 9:02 pm
a quick pic of my new project.
deadgrass
Re: new project
Post by deadgrass » Sat Mar 01, 2014 9:05 pm
oops just realised where i posted sorry admin.
Re: new project
Post by Minter » Sun Mar 02, 2014 7:27 am
What's the plan with this one then Dave?
Re: new project
Post by appyarry » Sun Mar 02, 2014 8:15 am
I like the front end, however not sure about the fairing/screen affair!
Each to his own :-)
deadgrass
Re: new project
Post by deadgrass » Sun Mar 02, 2014 8:39 am
Minter wrote:What's the plan with this one then Dave?
thought i would try to make a road/trail bike something that would tour a bit more relaxed but still be capable off road [its evolving as i build it ] up to now it has ccm upside forks, big brembo brake inc master cylinder,magura fat bars, 604 engine which by luck has a 670 cam so hopefully safe,kehin 41mm fcr carb, pro curcuit sillencer, rally raid ktm 690 dakar front and sides fairing with front light upgrade which has taken ages to fit, still lots to do :D
a few picks of fairing headlamp bracket design .
Englishman
Re: new project
Post by Englishman » Sun Mar 02, 2014 8:57 am
No offence meant I thought it was two bikes that had been put together with Photoshop to see if anyone would notice :oops:
Re: new project
Post by appyarry » Sun Mar 02, 2014 9:15 am
Nice Work, What did you use to support the Fairing, it looks like you used Ply to start off then it changes to a different material, or is it ply that has been painted?
Ta,
deadgrass
Re: new project
Post by deadgrass » Sun Mar 02, 2014 9:29 am
yes arry,ply to make the patterns then plastic chopping board [read about using this on one of the adventure bike forums] as its very tough and cheap riveted together with ally angle. stainless threaded bar with plastic central heating pipe over between as its a fixed fairing the steering has less weight so less rider fatigue in theory.
hey englishman hopefully look better once all the same colour :D
Englishman
Re: new project
Post by Englishman » Sun Mar 02, 2014 12:06 pm
I am sure it will. I look forward to seeing the finish job and good luck with the remainder of the project.
Re: new project
Post by Bunker » Sun Mar 02, 2014 1:56 pm
What an intriguing project, ill follow with interest :-)
Users browsing this forum: No registered users and 210 guests
