Fuel injected Armstrong 500? Am I mad?
Re: Fuel injected Armstrong 500? Am I mad?
As soon as it's running (and it will) I'd love to get it back on the dyno to see how close an injected system keeps to the stoichiometric optimum. Dean was quoting 12.5 so he obviously prefers them a tad richer.
I should be back in uk by 17th I'll send a pic of the R6 pump then.
MT 604 - bits of allsorts, CCM,, Brembo, hagon
12.5 is very rich but needs to be rich for max power but lambda is 14.7 which is what modern efi engines run at. I will probably go for around 14.
If I want to ever change it its just a matter of using my phone or laptop wirelessly and altering it.
MT560e
BMW R75/5
Honda CB250rs
MZ TS250
BSA M20
BMW R75/5
Honda CB250rs
MZ TS250
BSA M20
The idea of running close to the optimum 14.7 and then being able to stop, have a cup of tea, re-program to run for power is a great one.
Where can I source EFI parts to convert my 350??
Not including the micro squirt unit you could get everything for less than£150 2nd hand on eBay. Its just finding a throttle body that matches the engine size. I have read a write up from a guy who fuel injected a Dr 350 with success. He talked about using one of the throttle body's from a sv650.
MT560e
BMW R75/5
Honda CB250rs
MZ TS250
BSA M20
BMW R75/5
Honda CB250rs
MZ TS250
BSA M20
Looking forward to see this thing running. Nice work Nick.
Did about 7 hours of wiring today
Wrapped up all the wiring with decent loom tape and soldered all of the connectors.
Starting to look a little neater too. Managed to get rid of alot of surplus wiring that I will not use.
MT560e
BMW R75/5
Honda CB250rs
MZ TS250
BSA M20
BMW R75/5
Honda CB250rs
MZ TS250
BSA M20
- Contact:
Hardest bit is getting the right fittings on
Looks like you've done a good job
Sent from my iPad using Tapatalk HD
Progress!
Fitted the throttle body, fuel pump and regulator/filter
Well chuffed with the throttle body to airbox rubber (f650gs), it has a nice trumpet/velocity stack that sits inside the airbox and seals in the airbox inlet and onto the throttle body perfect.
MT560e
BMW R75/5
Honda CB250rs
MZ TS250
BSA M20
BMW R75/5
Honda CB250rs
MZ TS250
BSA M20
- Contact:
That does look good. Can't wait to hear it's running
Could be an early XMAS present for someone!
Going to try and get it running tomorrow fingers crossed, booked the day off so full day of tuning.
Going camping near Buxton, setting off Saturday so if it isn't sorted by then I will have to put the carb back on for the trip. Only a hours jab at the most.
MT560e
BMW R75/5
Honda CB250rs
MZ TS250
BSA M20
BMW R75/5
Honda CB250rs
MZ TS250
BSA M20
