MT 500 Scrambler
Bonnielad
Re: MT 500 Scrambler
Post by Bonnielad » Mon Jul 15, 2013 8:21 pm
The frame is a bitch to get all the matt green crud off. As a result of my impatience the gloss black isn't as perfect as I would like so i will rub it down and recoat it. The yoke looks good though. Because its cast ally, all I did was attack it with the wire brush on the drill.
If the finished project looks as good as it does in my imagination it will be a belter. Black frame, Ally mudguards, forks and yokes. Silver tank with coachlining - not too flash 'cos I would only get upset when I dint it!
2024 (2012) CCM MT230
2002 BMW F650GS
Bonnielad
Post by Bonnielad » Mon Jul 15, 2013 8:54 pm
I forgot to mention, I prepped the tank and then took it to a good friend of mine that is a wizard with an airbrush (check out http://www.cyclopshelmets.co.uk" onclick="window.open(this.href);return false; ) He is obviously doing the paint job, and I've re-shaped the saddle to resemble a 60's scrambler and taken that to be recovered. I think its worth mentioning how lucky I was with the tank. Imagine how difficult it is to find a rounder style tank that has the right fittings in the right places to replace the standard MT unit.
Hunting round Newark autojumble last month I found one that was almost a perfect match. I think its off a mid 70's Honda CB250 or 350. Outside was scabby black but inside looked rust free so I parted with fifteen of her majestiy's finest to give it a new home. All it needed was a slight modification to the rear bolt hole - and a lot of rubbing down. my only criticism is that its perhaps a little small. Here's a picture of its first trial fit.
2002 BMW F650GS
Post by Minter » Mon Jul 15, 2013 10:10 pm
Looking good Steve..
More pics needed in 'message board' size instead of default!
Bonnielad
Post by Bonnielad » Fri Jul 19, 2013 10:08 pm
Been working away for a couple of days so not a lot of progress. I'm hoping to get the frame painted this weekend. I've been in the garage tonight and cleaned the paint off the top yoke and handlebar clamps - looking good so far - I was disappointed that under all that paint, the bars are steel. I don't really want to paint them. Where's the best place for a ali replacements?
2002 BMW F650GS
surfermick
Post by surfermick » Sat Jul 20, 2013 7:11 am
the frame looks like its painted already, are you not happy with the results Bonnielad
frenchy3
Post by frenchy3 » Sat Jul 20, 2013 12:06 pm
The bike is looking good :D :D :D The best replacement for the standard bars has to be Renthals. Probably an enduro bend or dakar high if the cables are long enough. You could go for a standard height and raise them up later using bar raiser spacers.
MT 350 1996 The Albatross
Bonnielad
Post by Bonnielad » Sat Jul 20, 2013 7:56 pm
I'm quite happy with the span and size of the original bars, I just think alloy (or even chrome) would suit the rebuild better.
Anyway, after a late start I've managed to make some decent progress today. Most parts have now been dismantled, cleaned, stripped of paint and are now hanging in the garage waiting for the 2-pack shiny black paint to dry. Hopefully this is a turning point and tomorrow I should start turning spanners clockwise.....
2002 BMW F650GS
Post by Minter » Sun Jul 21, 2013 9:40 pm
Heres a couple of the motor going back together..
Helicoiling the stripped out threads..
Ports all cleaned and polished, valves relapped and now fitted..
New cam bearing fitted and a new needle bearing needed too as it makes a right noise.. Should be able to get one tomorrow and finish it off and fire it up ready for Steve to collect on Tuesday..
Bonnielad
Post by Bonnielad » Sun Jul 21, 2013 10:28 pm
Decided to stay in the batcave all weekend. The rebuild has begun...
2002 BMW F650GS
Post by Minter » Mon Jul 22, 2013 7:19 pm
Last pic of Steve's motor before he comes to collect it tomorrow!
I know there is a hole where the cam shaft should be! new BK bearing being collected tomorrow as it whined like a good un, then it'll be on the test bed ready to be fired up...
See you tomorrow Steve..
Users browsing this forum: No registered users and 31 guests
