Moscow John's Engine Rebuild
Moscow John shipped a 350 down to me to strip down and check out...
All good so far not a bad little motor.. its not seen many oil changes and basically needs a decoke.. Valves are still nicely seated and rings are almost like new.. Clutch and sprag clutch check this afternoon....
Ring end gap is almost like new..
Locating dowel for clutch case has a bit cracked off which made its way to the sump..
Re: Moscow John's Engine Rebuild
Is this the engine that's been to Moscow/Moscow and UK/Nordkapp/Moscow/UK 2 up ?
Hi Eric, No this is out of Johns other bike.. It will be transplanted into the Moscow bike ready for the pyrenees, then the Moscow engine will be stripped and checked which should be interesting!Wirralman wrote:Is this the engine that's been to Moscow/Moscow and UK/Nordkapp/Moscow/UK 2 up ?
at least you wont have to do the clutch
Do you need a hand with the gasket this time?
Mt ,604
Mt 350
Armstrong 500
Mt 350
Armstrong 500
Yes indeed. It could give a good indication of the weaker areas/ areas that wear or don't wear.then the Moscow engine will be stripped and checked which should be interesting!
....looking good Gary!.....it's going to feel like a new bike with this motor in it.....thanks for all your help.....
Engine going back together nicely, hopefully tinypic will be working ok today!
Nope! no joy with tinypic today either!
Anyway sprag is as new, same as clutch all i had to do was file some very shallow grooves out of the basket..
The bottom end is all now done, just the topend to decoke and put back together tomorrow night..
Try Photobucket mate it's loads easierMinter wrote:Engine going back together nicely, hopefully tinypic will be working ok today!
http://photobucket.com/" onclick="window.open(this.href);return false;
Users browsing this forum: No registered users and 59 guests
