Recomissioning Woodgate67
Re: Recomissioning Woodgate67
Thanks to Mel paying a visit last night a front brake lever and LH pannier support has been donated FOC, Thanks Mel - I thought your pink tie looked very smart!!
Errr, he's got a wig on.Minter wrote:My naughty nurse has blonde hair!ellrider wrote:StackerMel wrote:He does have a naughty nurse!!
Mel
Thank you kindly Sir for the parts you supplied Minter, new to all this forum stuff so taken a while to thank you and work out how this all works.vtrsp1da0 wrote:Happy to help a fellow member shame i didnt have the other bits he needed.
So far so good! The motor is a reconned one, although the sump drain plug has been crudely tapped and over sized. The primary filter is missing, just the threaded stub screwed into the frame - thought i'd sheered it off but nope nowt inside and you can see the saw marks! Wont be able to fire it up today as ive not got any primary filters.
New battery has been fitted - it turns over fine and has a healthy spark, needs a few bulbs or connectors sorting out..
Its green! With a hint of red - rust!
The bodged Primary filter!
No oil in the frame, only water!, Plenty in the sump though which looked clean..
Now to service all the brakes, forks, tyres tubes and make sure its good gfor an MOT...
You're a better man than me Gunga Din! Glad you haven't found it a complete nightmare, is the rust mainly surface only?
Minter wrote:So far so good! The motor is a reconned one, although the sump drain plug has been crudely tapped and over sized. The primary filter is missing, just the threaded stub screwed into the frame - thought i'd sheered it off but nope nowt inside and you can see the saw marks! Wont be able to fire it up today as ive not got any primary filters.
Nowt a good wire brush wouldnt sort and some nice green paint!
Done a bit more this evening, I'd forgotton what fun removing the CV carb is!
Mmm nice!
The workshop has had a make over from engine building to bike building!
Mmm nice!
Beats doing crank sets and double sets with copper hand benders and desludging a heating system!Minter wrote:Nowt a good wire brush wouldnt sort and some nice green paint!
Mmm nice!
woodgate67 wrote:Beats doing crank sets and double sets with copper hand benders and desludging a heating system!Minter wrote:Nowt a good wire brush wouldnt sort and some nice green paint!
Mmm nice!
What is the diameter of the red cross stickers on the fuel tank, thought I would source new ones for after paint job?
Hi Minter ,whats that yellow bike in the background is it a council bike
Users browsing this forum: No registered users and 208 guests
