Working project
SpringerMan
Re: Working project
Post by SpringerMan » Sun Mar 10, 2013 11:50 am
Mr Shiney wrote:
SpringerMan wrote:
Mr Shiney wrote:There is an earth point behind the horn and just above it on the coil that feeds that circuit. That is a common fault point.
cleaned that one first!!
You need to trace the circuit through then. Sounds like you have a break somewhere!
k thanks
ellrider
Re: Working project
Post by ellrider » Sun Mar 10, 2013 11:56 am
SpringerMan wrote:
ellrider wrote:Is one of your fuse/circuit breakers buggered? or live feed/connections to/from it broken?
I will try swopping connections to the spare breaker. cheers
Just check with a meter that you have 12v coming out of the breaker (and that the wire isn't broke in the ring terminal)
Usually horn and brake lights are on the same fuse that is why I am suggesting this, waiting for someone to tell me this is not the case on an MT.
Mark
SpringerMan
Re: Working project
Post by SpringerMan » Sun Mar 10, 2013 12:28 pm
Its not the breakers!! I guess it time to strip the wires back to find a break. Is there anyway to check if the break switches are faulty?
SpringerMan
Re: Working project
Post by SpringerMan » Sun Mar 10, 2013 12:30 pm
ie connect the two wires on the master cylinder together to complete the circuit??
SpringerMan
Re: Working project
Post by SpringerMan » Tue Mar 19, 2013 5:11 pm
All is good passed MOT last friday
Re: Working project
Post by Wirralman » Tue Mar 19, 2013 5:13 pm
Well done Geoff, another one back on the road
Users browsing this forum: No registered users and 71 guests
