You need to buy a wife! Lots to choose from, mine never cuts the cable and always tidy up afterwards.TDIPower wrote:It has just taken me 2 solid days just to cut my hedge and I only cut through the power cable once! I still need to clear up all the cuttings. Pete
TDI Powers 350 Engine Rebuild
Re: TDI Powers 350 Engine Rebuild
I have a wife and I didnt even have to buy her!! she's great round the house and italian so food is brilliant, the down side at the moment is she has a bun in the oven so has to keep resting.
Hedge + Land Rover = no hedge to cut any moreTDIPower wrote:
It has just taken me 2 solid days just to cut my hedge and I only cut through the power cable once! I still need to clear up all the cuttings. I have taken 2 ft off the width on my side and 3 off the top and its still 3ft wide and 8ft tall
Almost finished!
Georges valve spring compressor makes light work of refitting the cleaned, polished and reground valves..
Then 4 coats of paint...
Already to put back together with a new piston kit
Piston slid into cylinder with ring compressor then fitted over dowels to connect the gudgeon pin and circlips
Polished head and new o rings next.. and the remainder of Georges stainless nut and bolt kit!
Almost done
Just the starter motor and timing gear and a 6 minute run on the test bed..
Almost done
All back together, just need to fire it up - but at a more sociable hour!
meant to ask but as you know been somewhat distracted with life...
What was the state of the sprag, cam pulley (i know the lower had a few marks, I had 'skimmed it' myself as much as I dare) and the cam belt rollers bearings?
Did i keep the kick as well as the gear select? I know I took something off for ease of transit?
G'day Pete,TDIPower wrote:meant to ask but as you know been somewhat distracted with life...
Sprag OK Top Pulley OK timing bearings U/S and replaced. I have the kick start, Ive treated it to a lick of paint..
Petes Engine ran on the test bed tonight assisted by these two paasing by! Anyone recognise them!.....
Motor ran well and as it should and is now on its way back to Barnsley as i type!
Arkwright and Granville???
Users browsing this forum: No registered users and 67 guests
