Tim's Seized 500 Engine Rebuild
Re: Tim's Seized 500 Engine Rebuild
Post by Minter » Sun Nov 25, 2012 7:40 pm
TDIPower wrote:It was all I had about. I would have put bits up the front with a brace across the top (like the back) they would have made handles.
Could do with a drip tray in the base then it could all be wraped in cling film for shipping.
Brace fits perfect into some big green boxes ive got, that should contain any leaks etc and provide added protection, you'll no doubt get to see one soon!
Post by Minter » Sun Nov 25, 2012 7:43 pm
pupster wrote:...I reckon it could be time for Gary to give up the day job & enter the wonderful world of self-employment!.....Go on Gary!.... ;)
:lol: you never know John! We'll call it a weekend job for now and see how things go! I need to go back to work in the week for a rest!
timbradder
Post by timbradder » Mon Nov 26, 2012 11:49 am
Yes I think my engine is in good hands
Post by Minter » Fri Dec 14, 2012 6:04 pm
Important bits arrived for Tims motor, new liner and piston, liner away being fitted to original cylinder. Now the work can begin to get this motor back up and running!
danswankie
Post by danswankie » Sat Dec 15, 2012 9:23 am
i never knew the liner could be sourced as a seperate item i thought that it was moulded into the aluminium part of the cylinder ...was this an expensive part if you dont mind me asking ?
Post by Minter » Sat Dec 15, 2012 9:30 am
Hi Dan its not expensive compared to the piston but the pressing out of the old and pressing in of the new is! Then it has to be bored and honed to match the piston as its only a rough finish inside. As oversized pistons have run out and waiting to be manufactured its the only option as there are plenty of liners and standard pistons.
Post by Minter » Sat Dec 22, 2012 1:24 pm
Ive managed to do a bit more to Tim's motor this week whilst the new Liner is away being fitted..
Most of the oil and crud removed..
Sump wasnt a pretty site!
I'll give the gearbox a lick of heat resistant paint for you Tim..
Bottom pully looks a bit sad..
Good news is Gearbox and Crank all work a treat and hopefully i'll have the cylinder back on Xmas eve....
timbradder
Post by timbradder » Mon Dec 24, 2012 10:43 am
Thanks mate the frame has been sand blasted and taken with the plastics and other bits to be painted so hopefully it wont be long before I can start the rebuild so far I know I need yolk and swinging arm bearings which I have sourced on here along with complete set of stainless bolts not found handlebar controls yet or new wiring harness but may use old harness 8-)
Post by Minter » Wed Dec 26, 2012 8:50 pm
Done a bit more to Tim's motor this evening, even given the gearbox a lick of paint!
Head stripped and cleaned up a bit, should get, head and clutch built back up tomorrow now.. just waiting for a call from the engineering firm who has got the cylinder..
Shouldnt be long now Tim!
Post by Minter » Fri Dec 28, 2012 8:41 pm
Still waiting for the Cylinder to be relined, so rebuilt the clutch and various other bits and bobs this avo..
Kick start return spring put back together..
Then the clutch and all associated cogs.. Clutch basket has had all the grooves filed down
Nice clean sump with new O rings and gaskets
Then a new clutch went in.. Steels were all fine and have been reused.. New lock washer and torqued to 120Nm!
Clutch cover has seen better days due to corrosion inside and outside! Must have been a lot of water inside! I'll have to build up some of the case with JB weld so that the timing cover fits tight..
Plenty of corrosion this side of the motor too..
Nowt a lick of paint wont fix though!!
Users browsing this forum: No registered users and 68 guests
