Madstu's Minter Rebuild!
Re: Madstu's Minter Rebuild!
Minter said it doesn't work even with holding the wires together, so it's something other than the switch itself it seems.
If it's only a failure if the switch is present, then just remove the switch and hide the wire
HD MT604e - THE WUF
Armstrong MT405e - THE CNS
MadStu wrote:Minter said it doesn't work even with holding the wires together, so it's something other than the switch itself it seems.
That's what I meant
No problem, thank you
Stop lamps may operate in conjunction with either the front or the rear brake, or both. On machines first used on or after 1 April 1986, the stop lamps must operate by the application of each system.
http://www.ukmot.com/bike_1-3.asp#Text_top" onclick="window.open(this.href);return false;
Cheers Zip! Now ill have to get it sorted just to be on the safe side! Not that Stu uses them! Have you seen his BMW brake failure vid!!ZIP TIE wrote:Stop lamps may operate in conjunction with either the front or the rear brake, or both. On machines first used on or after 1 April 1986, the stop lamps must operate by the application of each system.
Bottom end all done now, Just the top end to stick back on now...
Oooh that looks painful! :O Thanks for all your hard work mate
HD MT604e - THE WUF
No probs mate! That'll be my cylinder honeing tool! Its fine when you get it in!!MadStu wrote:Oooh that looks painful! :O Thanks for all your hard work mate
That's what I told my girlfriend!
HD MT604e - THE WUF
MadStu wrote:That's what I told my girlfriend!
Motor now finished! Heres some pics of the top end going back on....
Head all de coked and valves lapped back in and new stem seals...
Glad Mike, John and Ruth are calling in tomorrow to help me lift it back into the frame!
Users browsing this forum: No registered users and 226 guests
