Woooooooooo!
First ride of the bike today, ran and pulled brilliantly Little rough at first, but once the accelerator pump had bled properly and the idle adjusted it was excellent.
Video below!
Headlight, new fuel tap and filter are on. Got a strap around the front brake lever overnight to try and get bled a bit better, if that doesn't work i'll try a syringe from the caliper.
Should be MOT'd this week!
Ben's MT350 Rebuild
Re: Ben's MT350 Rebuild
I had job bleeding the brakes and i found that leaving the bleed screw shut and just pump the lever it bleed its self its worth a try
Clamping the lever overnight seems to have worked well, nice and firm now.twmtomos1 wrote:I had job bleeding the brakes and i found that leaving the bleed screw shut and just pump the lever it bleed its self its worth a try
MOT today and she passed with no advisories Register tomorrow and then onto the road!
Bumped into a guy at the garage who's on here actually - got a few 500's and one with a sidecar - good to meet you - shout up!
That was me having my lunchneoxerox wrote: Bumped into a guy at the garage who's on here actually - got a few 500's and one with a sidecar - good to meet you - shout up!
1981 Suzuki GSX250E - Commuter
1986 Armstrong MT500 - Work horse - Needs engine rebuild
1987 Armstrong MT500 - Sidecar bike
1987 Suzuki RG125 - Project
1988 MZ ETZ 300
1988 MZ ETZ 300
Users browsing this forum: No registered users and 236 guests
