Project MT500 Twinshock Motorcrosser
Re: Project MT500 Twinshock Motorcrosser
Post by Minter » Sat Mar 31, 2012 6:05 pm
Thanks Mick, These pics aint quite so pretty!
First thing today..
Just after tea break..
Beaten into submission with a broken stud extrator..
Note the broken extractor in the middle of pic.. Doh.. :(
ninjacheese
Post by ninjacheese » Sat Mar 31, 2012 6:09 pm
Hi
That Blue bike is FANTASIC :D thanks for pics.
Trevor
vtrsp1da0
Post by vtrsp1da0 » Sat Mar 31, 2012 6:18 pm
Gary that type of extractor are a bit chocolate its a shame your so far away you could have used our impact extractor and the oxy/cet rig from work its better to use a small nozzle and heat around the area the stud goes into
All the best
Dave
Post by Minter » Sat Mar 31, 2012 8:11 pm
No worries Dave, every day is a school day! :)
vtrsp1da0
Post by vtrsp1da0 » Sat Mar 31, 2012 9:11 pm
School of life :lol: iam guessing you dindt serve in the R Engineers then :lol:
Post by Minter » Sun Apr 01, 2012 8:33 am
vtrsp1da0 wrote:School of life :lol: iam guessing you dindt serve in the R Engineers then :lol:
Nope! But if i had my time all over again i'd consider being a wedge head! :lol:
Post by TDIPower » Sun Apr 01, 2012 9:27 am
Just a note for drilling out the broken stud. they go into the head parallel to the head face so you can get one of these 90 degress drill blocks (sorry don't know the real name for them) basicly a big lump of machined 'angle iron' with fillets. Bolt the head to the vertical face using the hole for bolting it to the barrel, bolt the hoizontal to the drill bed.
Im faced with the same sort of problem as i have 2 studs still intack to remove. I got rid of my oxi rig 2 months ago :(
Are you going to get cleaning the lump up and spraying?
how far are you stipping it back?
Will you be using stainless studs on replacment??
Post by Minter » Sun Apr 01, 2012 9:56 am
TDIPower wrote:Just a note for drilling out the broken stud. they go into the head parallel to the head face so you can get one of these 90 degress drill blocks (sorry don't know the real name for them) basicly a big lump of machined 'angle iron' with fillets. Bolt the head to the vertical face using the hole for bolting it to the barrel, bolt the hoizontal to the drill bed.
Tried to do something similar with my drill press clamp but it wasnt big enough to secure the head firm enough to drill, hence my attempt free hand! Ive given it a fair shot so now over to an expert! I'll stick to what i know best!
Next step will be to clean everything up, sand down any major steps on the gear box ready for spraying, sand blast the casings then spray them.
Ive used stainless studs on my 604 from apophis last batch for the 350 engine are steel and brass also off apophis plenty of copper slip was applied to both sets of studs!
Good luck with your stud removal exercise! let us know how you get on Pete!
Post by Minter » Thu Apr 12, 2012 6:42 pm
The gearbox is now coming on.. Its been resprayed and all fastners replaced with stainless with plenty of copper slip and all torqued correctly.
The cylinder now appears to be scrap due to the deep rust grooves, Any half decent 500 cylinders in need of a good home just let me know - cash waiting!
Next will be the clutch rebuild....
vtrsp1da0
Post by vtrsp1da0 » Mon Apr 16, 2012 9:22 pm
How did you get on with removing the drill bit ?
